Right turn signal problem
Old Jan 5, 2019 | 01:18 PM
Dcrouch's Avatar
Dcrouch
2nd Gear
Default Right turn signal problem
I just replaced the headlight/turn signal switch on my 98 Vette. The headlights weren't flipping or lighting up and with the new switch they work perfectly, but now....
-Left turn signal works great front and rear.
-Hazards work front and rear.
---Right turn signal works in front BUT in the rear the left and right plus the brake lights are blinking. What happened? They were working fine before. Did I just get a faulty new switch? The replacement was fairly simple, not like I could mix up any wires.Thanks for any tips, I just swapped one problem for another.
Old Jan 5, 2019 | 01:40 PM
oelarse's Avatar
oelarse
I guess your hazardswitch may need to be replaced . The turn signals goes through the hazard switch as shown on these schematics .
Try to measure the voltage these bulbs are receiving from the turnsignal switch/hazards switch .
Old Jan 5, 2019 | 03:40 PM
Dcrouch's Avatar
Dcrouch
2nd Gear
I'll give that a shot and let give an update. Appreciate it.
To Right turn signal problem
