Advice on Optima battery spill
Old Jan 5, 2019 | 04:06 PM
SCALLOPED91's Avatar
SCALLOPED91
Default Advice on Optima battery spill
I regularly trickle charge my Corvettes. On my c5, I use an optima battery due to rumors I’ve heard of regular batteries leaking and frying the brilliantly placed computer below. I suppose I got a lemon because I managed to overload the battery with just regular charge and the battery blew the ports and looked like a steaming tea kettle. I removed the battery as soon as it was cool enough and I applied baking soda, which sizzled upon contact with the battery material. I dumped a whole box, messy yes, all over the entire battery area. I’m just wondering if I should vacuum this stuff out or use water to rinse the remaining residue off. Have a new tray on order and a new battery waiting but I just wandered what lengths I should go to and might have overlooked.
All help is appreciated. Thanks.
Old Jan 5, 2019 | 04:37 PM
bighank's Avatar
bighank
Default Use warm water and skip the new tray
I had my vacuum line for the HVAC melted by the battery acid when I bought the C5 used. Mix up a gallon or so of warm water and a good amount of baking soda and pour it all over the battery tray and nearby where the acid may have leaked. Might want to use a rag or brush if you can't get into tight places. Rinse with a garden hose for about a minute or so and then let the whole area dry out.
If you have paint damage can use a wire brush and then Rustoleum to cover areas where the acid has gone thru the paint. If you have to remove the tray go ahead but watch it as you can strip the retaining nuts for the bolts holding it in. Even with my severe acid damage the tray was not damaged at all. Must be made of something that does not get damaged by the acid.
Old Jan 5, 2019 | 05:40 PM
69's Avatar
69
Cruise-In VI Veteran
Additional Inspection areas in case of acid spill...
Remove the right front wheel/tire and remove the wheel house access panel. remove the battery tray, perform visual inspection for acid damage on the frame rail ( Insp all four sides of the frame rail, left, right, top, bottom) for paint /acid damage. Look closely at the area of the PCM to include PCM electrical plug and wires. Clean areas as necessary, restore frame rail surface protection (paint) as needed.
Cheers,
Goose
Battery Acid Inspection zone
Old Jan 7, 2019 | 07:31 AM
sirdano's Avatar
sirdano
Get a battery spill mat will help future issues
Old Jan 7, 2019 | 07:42 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
And you may want to look into a new/different battery charger. Yours is either defective, or not appropriate for an Optima battery.
Old Jan 7, 2019 | 09:01 AM
wcsinx's Avatar
wcsinx
But OptimaJim assured me that it's impossible for Optima batteries to leak.
Old Jan 7, 2019 | 12:56 PM
Josephu's Avatar
Josephu
Better to have leaked, than to have "Exploded"!!!
To Advice on Optima battery spill
