Oil Drain plug
Old Oct 30, 2002 | 06:15 PM
Wolf1171's Avatar
Wolf1171
From: Winter Jam I and II Veteran, Bahama Jam 2005 Veteran
CI 4, 5, 7, 9 & 10 Veteran
St. Jude Donor '03-'05-'06-'08
Default Oil Drain plug
I am attempting to change my oil and am having trouble getting the oil pan drain plug out (its really on there). Any tips?
Old Oct 30, 2002 | 07:24 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Default Re: Oil Drain plug (Wolf1171)
Shawn, use proper counter torque, make sure you're turning it the correct way (I know you are) and that bad boy should come off.....if you still have problems, let me know and I can drop by :)
Old Oct 30, 2002 | 08:44 PM
Wolf1171's Avatar
Wolf1171
Default Re: Oil Drain plug (Mean Green 2000)
I put so much pressure on it I almost hurt myself and it never budged. I think that however put in on last tightened it way too much.
Old Oct 30, 2002 | 09:07 PM
bcstonic's Avatar
bcstonic
I find with alum. fittings that a steady pressure does not work as well as a hard and rapid snap on the fitting. You might want to try it.As there is no oil pressure in sump the plug does not need to be cranked down extremely hard. Good Luck.Brian
Old Oct 30, 2002 | 09:36 PM
rdochterman's Avatar
rdochterman
Default Re: Oil Drain plug (bcstonic)
Two suggestions, 1. put your wrench on it, and tap the wrench firmly with a mallet, it should break loose.
2. Put a rachet on it, and slide a piece of pipe over the ratchet handle that is longer than the ratchet handle. It will give you a lot more leverage.
Just don't ever put it on that tight again. A stripped out pan would be very expensive to replace. Good Luck!
Old Oct 30, 2002 | 10:48 PM
los7883's Avatar
los7883
Default Re: Oil Drain plug (rdochterman)
Had the same problem myself...just put a piece of pipe over the end of the ratchet and turn that baby...the pipe will give you added leverage. I put so much into it my whole damn arm was sore the next day.... :smash:
Old Oct 31, 2002 | 12:19 PM
jerryv's Avatar
jerryv
Whoever did that should be hit. The drain plug should be torqued to around 22 ft lbs. Hope they didn't screw up the threads...
Old Oct 31, 2002 | 02:14 PM
2kbluestreak's Avatar
2kbluestreak
Default Re: Oil Drain plug (Jerry Velders)
Whenever I'm under the car loosening a bolt or nut, I find I always have to use the right hand rule, just to make sure I am not accidently overtightening. It is failsafe, provide I dont use my left hand. With aluminum, its really bad to overtighten, but I don't have much experience in loosening up really tight bolts in this material. I'd be afraid the threads could still be stripped on the way out. If it still doesn't come, I'd take your oil and filter to a quick change place where they could use an impact wrench. Better alternative to screwing up the pan threads. :cheers:
Old Oct 31, 2002 | 02:21 PM
Ron Cleaver's Avatar
Ron Cleaver
I would also spray some penetrating oil on it. WD-40 might do if you don't have penetrating oil.
[Modified by Ron Cleaver, 12:22 PM 10/31/2002]
Old Oct 31, 2002 | 04:26 PM
Wolf1171's Avatar
Wolf1171
Default Re: Oil Drain plug (Ron Cleaver)
I have some WD-40 and will give it a try.
I will do this if I can't get it off with the WD-40.
Thanks,
To Oil Drain plug
