C5 Engine Mounts Oil Filled?
Old Jan 13, 2019 | 03:15 PM
dale3guy's Avatar
dale3guy
Default C5 Engine Mounts Oil Filled?
I know C6 oil mounts are oil filled and leak oil when they are bad. Do the C5 mounts do the same? Or are they not oil filled?
Old Jan 13, 2019 | 05:54 PM
tbrowne's Avatar
tbrowne
C5 motor mounts are also oil filled - not sure if they are the same part number or not. They are strong and do a really good job isolating the body from engine shake and vibrations.
Old Jan 13, 2019 | 06:15 PM
Mark@AMT Motorsport's Avatar
Mark@AMT Motorsport
Supporting Vendor
They are indeed oil filled and make a lovely mess when they eventually go pop. If your car is a street car then I recommend replacing with stock mounts when they eventually fail. If if it's a track car and you're looking for a firmer ride then our Vulcan Motor Mounts become a viable option.
https://amtmotorsport.com/products/c...n-motor-mounts
Old Jan 14, 2019 | 08:20 AM
dale3guy's Avatar
dale3guy
Thanks guys! No signs of oil yet so I think they are still okay.
Old Jan 14, 2019 | 09:53 PM
_zebra's Avatar
_zebra
i was checking those out in case mine go... expecting about 650hp/600tq -ish from the updated blower setup
To C5 Engine Mounts Oil Filled?
