Anyone have C5Help.com wheel bearing replacement article saved?
Old Jan 15, 2019 | 08:15 PM
DrRaySomeDay's Avatar
DrRaySomeDay
Default Anyone have C5Help.com wheel bearing replacement article saved?
There is an article mentioned in old posts about a write-up with pictures to replace the rear wheel bearings. The link was https://www.c5help.com/C5_Rear_Wheel_Bearing.htm but it is dead now. Any help is appreciated!
Old Jan 15, 2019 | 08:29 PM
fuggles's Avatar
fuggles
Froggy has a video on youtube. Check that out.
I've done this a few times. Its pretty straightforward if you have the correct tools. I break the axle nut before lifting the car. Froggy doesn't do this.
