NEED HELP: ABS and Traction Control Lights
Old Jan 16, 2019 | 11:45 AM
Jeffreyb987's Avatar
Jeffreyb987
Cruising
Default NEED HELP: ABS and Traction Control Lights
When driving, I will hit a bump and it will trigger ABS and Traction control warning/service lights to come on my dash. It will thus turn off the traction control for the car. Has anyone had this problem, and how can I fix it?
Thanks,
Jeffrey Brown
Old Jan 16, 2019 | 12:23 PM
Smoken1's Avatar
Smoken1
Use the DIC and pull your codes... If you have never done it here is a video
Old Jan 17, 2019 | 10:10 PM
lonerider2002's Avatar
lonerider2002
Could be a loose wheel sensor or even a bad ignition switch( replacing mine fixed a lot of issues I was having). Post the codes-that will help to narrow it down.
To NEED HELP: ABS and Traction Control Lights
