Comand center buttons ??
Old Jan 17, 2019 | 07:11 AM
97Chuck69's Avatar
97Chuck69
Default Comand center buttons ??
On the 1997 there are 5/6 buttons on dash and when they are pushed you can read what they bring up down in the window in the instrument panel. When I push mine nothing happens. I can not check fuel, mileage, tire pressure or any thing else. Does any one have a idea on what is going on and is it tied in with the AC/HEAT control unite.
Old Jan 17, 2019 | 09:19 AM
3sACROWD's Avatar
3sACROWD
For future reference, the buttons you are asking about are called DIC (Driver Information Center) buttons. There is likely something going on with the instrument cluster. Hopefully someone more knowledgeable will chime in.
There is no correlation between the DIC buttons and the HVAC unit. What is happening with the HVAC unit; dim display?
Old Jan 17, 2019 | 08:26 PM
FX VETTE's Avatar
FX VETTE
If you are a DIYer...I would put in another DIC switch like this -
97-04 CORVETTE C5 DRIVER INFORMATION CENTER BUTTON DIC SWITCH U66 https://rover.ebay.com/rover/0/0/0?m...2F142962640361
These instructions (below) aren’t meant for the DIC, but they will get you where you need to be -
https://web.archive.org/web/20070128...zel_howto.html
I’ve removed the gauge cluster a few times. Once to replace the DIC switch and 2 other times to change out lights behind the DIC and HUD to red LEDs. It’s not hard, just time consuming. A 2/5 difficulty level IMO. Good luck.
To Comand center buttons ??
