Changing gear oil
Old Jan 17, 2019 | 05:58 PM
1999corvettels1's Avatar
1999corvettels1
Default Changing gear oil
This will be my first gear oil change and T56 fluid change, guess they are long overdue but better late than never.
Anyways is this the correct stuff for the differential?
Bought 2 quarts.
Old Jan 17, 2019 | 09:59 PM
crf450x's Avatar
crf450x
That is the correct fluid
Old Jan 17, 2019 | 10:06 PM
1999corvettels1
Guy at autozone tried to sell me the additive, but I said this already has it.
Just making sure.
Old Jan 18, 2019 | 11:19 AM
JHrinsin's Avatar
JHrinsin
Most GL-5 gear oils now contain the friction modifiers suitable for use with factory type clutch-type limited slip differentials and for most of these LSD no additional friction modifiers are required. Remember that too much as well as too little of these friction modifier additives are a bad thing. You should be fine with the Mobil 1 75w-90 fluid that you bought in a stock differential or any other high quality synthetic GL-5 fluid from say Redline, Amsoil, Royal Purple or GM.
Now if you have a differential that was setup by someone in the aftermarket like say Rick at RTK, then I would follow whatever they recommend that you to use due to their possible special setup of clutch material and/or how tight they set things up. The key for a street driven C5 is to make sure the LSD does not chatter during a fairly tight figure 8 maneuver in an open parking lot. Also if you are road racing your C5 or happen to do a lot of track day events, then a different fluid maybe needed.
Old Jan 18, 2019 | 12:55 PM
1999corvettels1
Ok this should be fine, car is stock and I just drive on streets and freeways.
Thanks guys
Old Jan 18, 2019 | 01:24 PM
helga203's Avatar
helga203
Thanks guys
That's what I just put in my 1000hp vette. No additive
Old Jan 18, 2019 | 01:27 PM
foggy's Avatar
foggy
I think you are going to need more than 2 qts.. Especially since it's very difficult to get it all out...
I also squeeze several ounces thru when drain plug is out and empty just to "flush" out some crap in there.
You will need to add the LS additive IF you get any clicking/popping noises while cornering.. You'll prob be ok.. I Usually add it /
Old Jan 19, 2019 | 02:25 PM
GeneralMotors4Life's Avatar
GeneralMotors4Life
You will need to get a hand pump to get the fluid into the trans and rear. Hopefully you have one already! Good luck
Old Jan 19, 2019 | 03:28 PM
1999corvettels1
I did buy a new hand pump, also.
To Changing gear oil
