What injectors to use, Stock,or upgraded???
Hi Everyone! I'm starting some performance mods on my 99 Convertible. Dorman ls6 intake, 1 7/8 long tube headers, CAI dual filter intake, and a BTR stage 2 camshaft kit. 90mm holly TB, with holly 5/8 fuel rails. Y pipe, with cat backs. With a power tune. My question is what size/lbs injectors to use, or will the stock injectors be ok??? Your experience, and input would be greatly appreciated. Thanks!!
Received 1,261 Likes
my stock ones were maxed at ~420rwhp, something like 42lb would be enough and probably give you some head room
When looking at injectors one item to keep in mind is most companies rate their injectors at 3 bar while GM uses 4bar of pressure. A 36lb injector at 3 bar will be very close to 42lb at 4 bar. Since we do not know your cam specs you should consult the builder as to what he recommends.
+1. Get 42lbs@58PSI and you will be good and some room for growth for about up to 500WHP or a bit more. Fuel Injector Connection is a great source for refabbed LS1 injectors resized and bench flow matched. I got mine from them and I'm very happy with my results.
