Corvette Camaro Tuner in Tampa E85
Former Vendor
St. Jude Donor '12
Check out my website -->>>> www.TampaTuning.com
Check out my YouTube channel https://www.youtube.com/user/tampatuning/videos
I calibrate the most LS series cars in the Tampa area with Corvettes and Camaros being my highest volume cars to tune .
Tampa Tuning is the home for street performance tuning starting at $325 Corvettes and Camaros at the stock to bolt ons level. My street tuning process takes several hours to complete. Its the best way to collect scanner data for low end drivability, cruising, and WOT under actual load and airflow of the vehicle.
My HP Tuners interface has unlimited credits for LS1, LS2, LS3, LS6, LS7, LSA, LS9, L99 engines
C7, Gen6 Camaros, and trucks are $100 more.
Great modification for the buck!
Instagram : TampaTuning
OUR TOTAL STREET PERFORMANCE TUNING PACKAGE FOR GM LS1-7 VEHICLES IS $325.00 WITH TRANSMISSION PACKAGE INCLUDES: www.TampaTuning.com
Read and reprogram your PCMs settings and perform real time scanning diagnostics for the best results
Increase power enrichment rate mode
Examine and change timing tables for additional horsepower & torque gain
Optimize your vehicles Air and Fuel Ratio monitored by the NGK/ AFX wideband unit
Reduction of intake air temperature table (heat soak)
Desired rev limiter adjustments
Park, neutral, and in- gear idle adjustments with and without A/C active
Adjust power enrichment delay to immediate
Engine torque management system reduced
Transmission torque management system reduced
Transmission shift points enhanced
Transmission shift times reduced
Transmission shift pressure firmness enhanced if needed
Skip shift deleted (CAGs 1st to 4th )
Fuel injector rescaling for aftermarket injectors if needed
Cooling fan activation temperature and percentage of cooling recalculated
Perform speedometer re-calibration for rear gear ratio and tire size change
Turn off check engine light and remove trouble codes
www.TampaTuning.com
Email Click here :
Tuning@TampaTuning.com
Phil
www.TampaTuning.com
Email Click here :
Phil
Former Vendor
St. Jude Donor '12
Corvette Camaro tuner in Tampa E85
Read some comments about Tampa Tuning : https://shop.tampatuning.com/testimonials.html
Read about what I change : www.TampaTuning.com
I calibrate the most vehicles in the Tampa area for the best price !
Check me out on Facebook : Tampa Tuning
Instagram: TampaTuning.
Want to go faster? Email me : Tuning@TampaTuning.com
Phil
Phil
www.TampaTuning.com
Email Click here :
Phil
www.TampaTuning.com
Email Click here :
Phil
Former Vendor
St. Jude Donor '12
I calibrate the most vehicles in the Tampa area and for the best price !
Corvette Camaro GTO Cadillac CTSv Challenger Charger Truck Silverado Sierra Yukon The BEST Tuner in Tampa
Phil
Phil
Phil
Phil
Former Vendor
St. Jude Donor '12
Corvette tuner in Tampa
Check me out on Facebook : https://www.facebook.com/tampa.tuning
Corvette Camaro Cadillac CTSv Challenger Charger Tuner in Tampa
Email Click here :
Phil
Email Click here :
Phil
www.TampaTuning.com
Email Click here :
Phil
www.TampaTuning.com
Email Click here :
Phil
Former Vendor
St. Jude Donor '12
Corvette Camaro tuner in Tampa E85 cammed headers
