The rear tires will be the same size as stock so your speed will read correctly.
I don’t think so. Mine is a 1999 FRC. I believe these were 17/18 setup originally, and C6Z06 are 18/19. Tire diameter must be different. Ok, but now I know it’s the rears that do the reading.
The 275/40-18 tire is exactly the same diameter as the 325/30-19 tire.The sidewall is shorter on the 19.That makes up for the difference in wheel diameter.
Gotta admit, you were right all along. The proof is in the pudding: I verified speedo speed vs. GPS speed on phone and it was spot on up to 90mph. Thanks.
