Active handling does not work
Old Jan 26, 2019 | 11:34 AM
Ted haller's Avatar
Ted haller
3rd Gear
Default Active handling does not work
i keep seeing comment that I need to replace EBCM. I talked to a Corvette mechanic who said this is rarely problem. He said it is usually one of the sensors. I can not find anything that show location of sensors so I could see if there is power to them
Old Jan 26, 2019 | 11:37 AM
Phanni's Avatar
Phanni
What year is your car?
Old Jan 26, 2019 | 12:31 PM
Smoken1's Avatar
Smoken1
What codes do you have? Use the DIC to pull your codes
Old Jan 26, 2019 | 12:49 PM
Ted haller's Avatar
Ted haller
3rd Gear
Old Jan 26, 2019 | 12:50 PM
Ted haller's Avatar
Ted haller
3rd Gear
Code c1214
Old Jan 26, 2019 | 01:13 PM
rrwirsi's Avatar
rrwirsi
From the C5 Code List
C1214 - Sol Valve Relay Contact or Coil CKT Open
Old Jan 26, 2019 | 01:15 PM
Smoken1's Avatar
Smoken1
C1214 Solenoid Valve Relay Contact or Coil Circuit Open.. Most common cause is the EBCM need repaired also check the ground pack on the left front frame rail.
File Type: pdf
Old Jan 26, 2019 | 05:39 PM
Jackie N's Avatar
Jackie N
EBCM repair isn't that costly. Maybe even cheaper than replacing most sensors. But yes it's prudent to verify sensors and wiring first before going further .
Old Jan 26, 2019 | 06:01 PM
Velocity_Vette's Avatar
Velocity_Vette
You need a new Corvette mechanic
Old Jan 27, 2019 | 12:07 PM
Moved to C5 Tech.
Old Jan 27, 2019 | 03:01 PM
oelarse's Avatar
oelarse
Maybe this is the way to go
https://www.corvetteforum.com/forums...r-fleabay.html
To Active handling does not work
