Can't Rrember
Old Jan 26, 2019 | 04:52 PM
gonec5's Avatar
gonec5
Default Can't Rrember
Is it normal to be able to remove the the ignition key while the car is running?
Old Jan 26, 2019 | 06:46 PM
Rexde1's Avatar
Rexde1
Nope.
Old Jan 26, 2019 | 07:23 PM
Josephu's Avatar
Josephu
Yes.......If its a 53 Chevy!!!
Old Jan 26, 2019 | 08:14 PM
gonec5's Avatar
gonec5
That is what I thought
Old Jan 26, 2019 | 08:36 PM
dhorner77's Avatar
dhorner77
It's a special feature so you can lock the car while you warm it up.
Old Jan 27, 2019 | 10:40 AM
SG Lou's Avatar
SG Lou
Old Jan 27, 2019 | 01:47 PM
bighank's Avatar
bighank
Default Your lock cylinder is shot
Had a bad cylinder (VATS sensor was shot). Got a used Ignition Switch (cylinder+electrical rear part) + interlock cable, plastic front bezel, from a junk yard. Had cylinder re-keyed at a dealer for $25 (locksmiths wanted $150 to $250). Shop around and fix it before you wind up somewhere with a dead C5 and need to be towed home.
To Can't Rrember
