MAT Upgrade
Old Oct 31, 2002 | 02:10 PM
skidmarc's Avatar
skidmarc
Default MAT Upgrade
What do you guys think of the MAT upgrade/relocation.....I read a post that it does nothing but cause detonation..is this true? I had one on my 00 and thinking of putting on my 99 along with the vortex power duct....also on my 00 I located it in the front most part near the MAF on the underside of the powerduct.
Marc
Old Oct 31, 2002 | 03:37 PM
scool93535's Avatar
scool93535
Default Re: MAT Upgrade (skidmarc)
I believe it's a 97 / 98 mod. The factory relocated the MAT in 99. Somebody jump in here if I got my years wrong. :cheers:
Old Oct 31, 2002 | 03:57 PM
chuckster's Avatar
chuckster
How a relocated MAT causes Detonation is beyond me... :rolleyes:
The MAT sensor is there for one reason..To tell the PCM how hot the air is coming in. Depending upon how hot the air is and the engine load it pulls timing from 1 to 6 degrees..
If you are getting detonation you either have other problems or the Air temps are astronomically high.
I have run a timing tricker which forces the PCM to read 57 degrees regardless of the real temps and never got detonation. I have since zero'd out my IAT table to kill any temp induced timing retard... ;)
Don't waste your money on the relocated MAT, just go to Radio Shack and get a 4.7K ohm resistor and plug it into the socket for the IAT sensor. This will make the PCM think it's reading 57 degree air..
[Modified by chuckster, 1:59 PM 10/31/2002]
Old Oct 31, 2002 | 10:18 PM
C5XTASY's Avatar
C5XTASY
Default Re: MAT Upgrade (chuckster)
Interesting post. I have noticed that between 75 and 80 degrees outside air temp, there is a difference in off the line punch (decreases). One question: If a timing tricker resistor is installed, as you can't always hear knock with the human ear due to exhaust noise or the knock being subtle, are the knock sensors sensitive enough to protect the car by backing off timing if knock does occur at higher temps? Thanks!
Ed
Old Oct 31, 2002 | 10:27 PM
chuckster's Avatar
chuckster
Default Re: MAT Upgrade (C5XTASY)
Ed
Are you saying 75 to 80 makes your car sluggish? The IAT does not even start retard until 104 degrees..
Yes the knock sensors are always working...period. They sense knock and pull timing immediately.
The IAT retard table pulls timing whether it's needed or not..It is not based on knock.
Old Oct 31, 2002 | 10:59 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
The relocated MAT Sensor caused me to have 8 degress of knock retard on my 00, I think it did work for years 98-99!
have one in the garage for sale, $15 free shipping!
Old Oct 31, 2002 | 11:25 PM
chuckster's Avatar
chuckster
Default Re: MAT Upgrade (wallstAL)
I am curious...If you got 8 degrees of k/r then you must have been Autotapping..
If you were tapping then WHAT temperature was being shown by the relocated sensor?
There could not be a great deal of temp diff at all.
I suspect people had bad sensors that actually caused the PCM to see a high temp instead of the intended low temp..
I be interested in seeing if the resistor trick would cause the same k/r... It does not add up
Old Nov 1, 2002 | 12:05 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Back in 00 Steve Cole hooked up a scan tool to the PCM using, what I think was a Tech II. I was driving and he was monitoring the Tech display. I just remember, Steve saying I had 8 degress of KR, he removed the MAT Sensor and the KR went to zero. This was when Steve installed the first of my four Powerloaders.
[Modified by wallstAL, 8:07 PM 10/31/2002]
Old Nov 1, 2002 | 10:05 AM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
I have a '98 and It didn't work for me either! :nonod:
:cheers:
Old Nov 1, 2002 | 03:16 PM
Jack Behrle's Avatar
Jack Behrle
Believe this is useful only up to 98 models. I installed one on my 99 FRC and although bottom end felt marginally stronger, detonation started at 5500 and then timing also pulled back on full throttle acceleration.
Bottom line, a waste of $ on 99 and up!
Old Nov 1, 2002 | 04:50 PM
skidmarc's Avatar
skidmarc
ok what exactly is detonation??
Old Nov 1, 2002 | 05:57 PM
RPOZ4Z's Avatar
RPOZ4Z
pinging.
my timing was also being pulled at higher RPM's, I went back to the factory IAT sensor and everything was fine. :cheers:
To MAT Upgrade
