Fuel rail questions
Old Jan 28, 2019 | 06:56 PM
Gunnmetalblue's Avatar
Gunnmetalblue
Default Fuel rail questions
Thinking about installing these fuel rails: https://www.jegs.com/i/Holley/510/534-210/10002/-1
Before anyone asks why, and points out that the stock rail is fine or that I should just paint or powder coat the stock one let me say I know this is unnecessary. It is strictly for aesthetics.
I have a couple of questions.
1: Is the circled part of the stock rail the pressure regulator, and if so what would be the effect of the Holley rail not having one?
2: I live in California; will there be any negative impact to passing smog with aftermarket rails?
Thanks for your input.
Old Jan 28, 2019 | 08:16 PM
StingrayRebel's Avatar
StingrayRebel
the piece circled is a pulse dampener, your regulator is either part of the fuel filter or in your tank depending on the year of the car
Old Jan 28, 2019 | 09:17 PM
Gunnmetalblue
What potential issues from not having one on the Holley rails?
Old Jan 28, 2019 | 09:57 PM
StingrayRebel
none, I don't have one on my rails and you would never notice it's missing (except for the look obviously)... if it will pass smog in your area I'm not sure but I don't see any reason why it wouldn't since that piece is not emissions related
Old Jan 29, 2019 | 02:32 PM
megan.andrews's Avatar
megan.andrews
Usually a sustained full throttle test is to see whether the fuel rail can hold commanded pressure rather than hitting it briefly and then falling.
To Fuel rail questions
