oil drain
Old Oct 31, 2002 | 02:28 PM
skidmarc's Avatar
skidmarc
Default oil drain
You guys see any problems with opening up drain plug to take out a lil excess? I filled it a smidge over full....cant I just loosen plug a lil and take some out? Or will plug not seat right again unless I empty and clean area then tighten??? Dumb question...I know
Old Oct 31, 2002 | 02:31 PM
EHS's Avatar
EHS
Default Re: oil drain (skidmarc)
A "smidge" over full isn't a problem. Trying to drain out "just a bit" isn't worth it if the overfill is 1/2 quart or less.
Another more fun alternative to reducing the oil level is to drive really fast at high rpms -- Chevy recommends overfilling for racing purposes -- you can probably burn off the "smidge" in no time.
Old Oct 31, 2002 | 02:50 PM
Moundir's Avatar
Moundir
Default Re: oil drain (EHS)
You dont have to drive really fast, just spin the motor at or near redline for a good 20 min and that will take care of your problem :yesnod: Ehs is right, that it's not worth it to try to drain it out :seeya
Old Oct 31, 2002 | 03:14 PM
skidmarc's Avatar
skidmarc
well I plan on starting an oil consumption test so I dont want to have it over full!
Old Oct 31, 2002 | 11:14 PM
Richin Chicago's Avatar
Richin Chicago
Just make a note of where the stick is. It will still be a valid test if you compensate.
Old Nov 1, 2002 | 11:02 AM
carpe dm's Avatar
carpe dm
I think they are right, but if you must get a little out, you can always pull the filter. For other reasons, I had to do this once and it worked well. I dumped about half of the oil (more runs down and out and is very messy) and re-seated the filter without problem. :yesnod:
Old Nov 1, 2002 | 11:48 AM
jerryv's Avatar
jerryv
Default Re: oil drain (carpe dm)
If you HAVE to remove oil, and don't have a suction pump, I think the filter is the way to go. Trying to get just a little out of the drain plug would be a messy PITA.
To oil drain
