Front right brake locks under heavy braking.
Old Jan 31, 2019 | 08:47 AM
Rob 93ZR-1's Avatar
Rob 93ZR-1
From: Fear causes hesitaiton...and hesitation will cause your worst fears to come true. Houston TX
Cruise-In IV Veteran
Cruise-In VII Veteran
Default Front right brake locks under heavy braking.
1999 FRC. Replaced both front calipers and changed over to stainless brake lines. No change.
looking to add bias spring to master cylinder, but this seams to be a band-aid, not a solution.
Is this a hydraulic problem or an electronic problem? ABS seams to work otherwise.
Thanks in advance!
Old Jan 31, 2019 | 10:36 AM
Gordy M's Avatar
Gordy M
Have you pulled the DIC codes, the only time my brakes locked up was when my harness came loose from the wheel bearing clip. Checked my codes and new where to look, in my case left rear brake.
Old Jan 31, 2019 | 10:48 AM
Rob 93ZR-1's Avatar
Rob 93ZR-1
I will give that a shot. Thank you!
Old Feb 1, 2019 | 08:12 AM
SaberD's Avatar
SaberD
Do you have the same issue if you disable ABS?
Old Feb 1, 2019 | 09:39 AM
Rob 93ZR-1's Avatar
Rob 93ZR-1
Default Laundry list of codes to sort through...
C1286
C1281
C1255
C1222
C1221
Got my work cut out for me. 🙄
Old Feb 1, 2019 | 01:05 PM
Gordy M's Avatar
Gordy M
More than likely have a SWPS sensor go bad and on the 99-00 it cannot be updated to the 01-04 sensor. Yours is no longer available. The only available option is to find a used one, preferably one that has been centered by a reputable vendor, and replace it. If you need how to do it I have a few downloaded article on centering the SWPS (easier with a Tech2) and removing the steering wheel to replace it.
Old Feb 6, 2019 | 02:01 PM
Rob 93ZR-1's Avatar
Rob 93ZR-1
Cleared codes. Drove for a day. All that remains is the C1286.
verified front suspension components all good.
I will chase down C1286 code, lots of reading and bad news, but the BIG QUESTION..
Is this the root cause of my right front brake locking up under panic stop situation?
Thanks.
To Front right brake locks under heavy braking.
