Light, Intermittent Lifter noise
Old Feb 1, 2019 | 11:03 AM
turabo87's Avatar
turabo87
Default Light, Intermittent Lifter noise
Hi folks,
Looks like I might have what seems to be a light and intermittent lifter noise. I hadn't noticed until I took my car to the tire shop and one tech noticed. He's done LS builds before and apparently has a good ear. It's hard to notice because it's a light tap, but it does sound intermittent which leads me to believe that it actually might be a lifter. I timed the intermittent tap and when it does sound, it taps at somewhere between 6-8 taps per second at idle, which matches the camshaft/valve/lifter rhythm. It's a huge bummer because these are new LS7 OEM/GM lifters that went in when I did my cam build, along with new BTR hardened 7.400 pushrods. Anyhow, I don't see any performance issues and I'm not too worried, but it's still a moderate concern. Knowing that these lifters are brand new, and knowing I did the correct procedure and correct torque value when I torqued the rocker arm bolts, what could have caused me to have this intermittent lifter noise? Might I be able to remedy it with some sort of oil modifier? or maybe by loosening all rocker arm bolts and doing the correct retorque procedure all over again? Or maybe I should shim the rocker arms next time? Basically looking for any possibility to try except taking the friggin heads off and replacing brand new LS7 lifters all over again.
FYI: I'm basically dailying my Vette, and I've beat on this engine HARD with no mercy since I did finished my cam build and car performs flawless everyday, at every load and every RPM.
Old Feb 1, 2019 | 12:25 PM
TastyBacon's Avatar
TastyBacon
Is it loudest around 2,000 RPM? If so, my rebuilt engine (also new LS7 lifters in new LS2 trays with aftermarket hardened pushrods) has been making the same noise for almost 10k miles now. During that time it's been through two HPDEs and has run 10psi of boost for the last 2k miles or so. Oil pressure is great, performance is great. I have messed with pushrod length and measured preload with a dial indicator and I'm sure it's dead on, makes no difference. I send the oil to Blackstone every change, so hopefully I'll know in advance if it's coming apart.
I have read about the same issue many times on LS1Tech with no conclusion. It used to bug the hell out of me but I've finally made peace with it and just enjoy the car. Good luck!
Old Feb 1, 2019 | 12:31 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Do you still have that "cold start" issue ??...I believe you posted a few days ago with this issue ??
Old Feb 1, 2019 | 12:38 PM
aaronc7's Avatar
aaronc7
Good idea tapping the counts per second, I've done the same thing by taking a video and slowing it down. Did you use a pushrod measuring tool? Mine needed shorter pushrods with cam swap. Wouldn't hurt to pull the valve covers off and check what you can.
I had a light tapping noise that was 1/2 engine speed when I cracked #7 piston. I swore it was a top end issue but still towed the car home to be safe. Another guy who owns a shop that does lots of work on vettes thought the same thing. I highly doubt that's it, but it could be something else. Sounds are hard to track down sometimes. Do you have a stethoscope tool by chance?
Old Feb 1, 2019 | 06:30 PM
turabo87's Avatar
turabo87
Yep, that’s a separate one. Does it every time the coolant temp is below 100F. Like clockwork engine reacts and ECU takes control of throttle past 100F. Im convinced it’s something missing in the tune.
Old Feb 1, 2019 | 06:37 PM
turabo87's Avatar
turabo87
I didn’t use a pushrod measuring tool. I went by what has been done before successfully with that cam, which is standard 7.400 pushrods. It’s a mild JEGS/SloppyMechanics Stage II .585/.585/228/230 112LSA.
I dont have a stethoscope. I’m going to try out running a bottle of Rislone oil additive. It’s been a proven product against stuck/dirty hydraulic lifters. Being that my lifters are new and my noise is so light and intermittent, i think it’s worth a shot.
i doubt I have any serious issues. Engine runs healthy, runs like a champ, and pulls hard. Had zero issues during dyno tuning too. If that doesn’t clear the noise, I’ll pull the valve covers.
Old Feb 1, 2019 | 07:27 PM
turabo87's Avatar
turabo87
Hard to say when it’s loudest because as RPMs go higher it just dissipates and hides among all other valvetrain noise. I’d say I notice it more between idle and 1500.
Old Feb 1, 2019 | 07:40 PM
ZERRY 316's Avatar
ZERRY 316
Originally Posted by turabo87
Hi folks,
A "tire shop tech" told you about an engine noise?
Old Feb 1, 2019 | 07:55 PM
aaronc7's Avatar
aaronc7
If you're going to pull the valve covers I recommend measuring required pushrod length while you're there. Whatever I read on the forums that my length "should be" ended up not being the case for me. Tool is cheap and pretty easy to do. You can probably measure the 4 corners of the engine to confirm or deny.
Old Feb 1, 2019 | 08:29 PM
bwill03z's Avatar
bwill03z
Do you have a video of the lifter noise? Also do you have a video of the cold start noise? If so post them.
Old Feb 2, 2019 | 09:52 AM
turabo87's Avatar
turabo87
Ill try to get a video of what I think is lifter noise. Don’t get mixed up with the cold start issue. I have no cold start noise. That’s a separate thread and has nothing to do with this lifter noise. It’s an issue that has to do with my tune, my car won’t hold idle during a cold start on its own without me holding throttle a bit, until coolant temp reaches exactly 100F. It’s a tuning issue.
Old Feb 2, 2019 | 03:22 PM
turabo87's Avatar
turabo87
Video link below.
Ignore “check gauges”. I was on empty at the gas station.
Old Feb 4, 2019 | 05:51 PM
turabo87's Avatar
turabo87
First video kinda sucked so I made a couple more with actual driving. Also, the noise is a little more prominent in these vids.
Old Feb 4, 2019 | 08:22 PM
bwill03z's Avatar
bwill03z
Mine sounds like yours on all cold starts or if it sits for a couple hours. Mine will go away when warmed up though, does yours not go away? Here is a video of mine on a cold start
Old Feb 5, 2019 | 08:21 AM
turabo87's Avatar
turabo87
https://youtu.be/OYUkaFeVVSQ
Mine ticks pretty much all the time to varying degrees, but I hear it more prominent now I guess because I'm paying attention to it now. I'd like to know if I can check for a collapsed lifter without taking the heads off. I was thinking of taking valve covers off and checking for any lash in between rocker arm seat and valve top BUT I don't know if these hydraulic lifters are supposed to keep enough internal pressure to maintain zero lash when engine is off and when lifter is seated on the base circle. If I can find that indeed I have a collapsed lifter, then I'll bite the bullet and plan for removing the heads again and changing the faulty lifter. I'm already 900 miles in after the top end rebuild and cam swap. I'd still like to try running a quart of Rislone oil treatment first before I try anything major.
PS: I can live with noise if it's a normal valvetrain noise, but if it's a potential of lessened engine longevity and wear, I'm not going to risk it.
Old Feb 5, 2019 | 10:13 AM
wcsinx's Avatar
wcsinx
Oil treatment isn't going to do anything considering that engine is basically new.
I almost hate to say it, but your combustion sounds a little off in the "Test Drive 3" video. I've come to expect a lot of valve clatter from these cars, but what I hear aside from that is a partial miss in your exhaust tempo which certainly could indicate a collapsed lifter.
Old Feb 5, 2019 | 11:43 AM
bwill03z's Avatar
bwill03z
Take a mechanic stethoscope or a long screwdriver and try to pinpoint which side the tick is on, pull that valve cover and check each rocker to see if you can push down on your pushrods. There shouldn’t be any movement there. I’ve done this on mine to both sides but all the rockers were tight so I’m really confused on mine. Where yours never goes away I hope it’s not a damaged roller on the lifter.
To Light, Intermittent Lifter noise
Old Feb 5, 2019 | 11:46 AM
turabo87's Avatar
turabo87
A partial miss?? Well, that's a new one I haven't heard before, I didn't pick up any partial miss. Anyway, I think we can guess and dispute all day long and it will still boil down to me taking at least the valve covers off and checking for a collapsed lifter, one rocker arm at a time. Being that this is relatively easy and quick, I'll probably do this first before anything else. Nothing more than I hate than having to go over the same job twice, especially when I know I did everything by the book and with new lifters. If I have to take the damn heads off.......who knows, I might just go all out and get refurbed 243/799 heads and ditch the 853's
Old Feb 5, 2019 | 11:50 AM
bwill03z's Avatar
bwill03z
Let us know what you find. I’m going to do mine again just to be sure.
Old Feb 5, 2019 | 02:01 PM
wcsinx's Avatar
wcsinx
I could be wrong, but your exhaust note sounds a little off in the way I've come to associate with a cylinder not quite firing the way it should. And I've found that you do actually have to run pretty far out of whack before the ECM will throw codes for a misfire. Listen carefully around 0:55 to 0:57
