LS1 - Upgrade to LS6 Valve Spring Install Video
Received 1,248 Likes
St. Jude Donor '21
With the addition of the A&A supercharger, spinning the stock engine to 6500 RPM'S on stock valve springs is not a good idea.
After careful thought, I decided to upgraded to LS6 springs. While I was at it, I made a detailed video of the process in case you were wondering what all is involved.
Thanks,
Ken
Thanks,
Ken
Robrote (02-05-2019)
Received 19,305 Likes
'20-'21-'22-'23-'24
Moved to C5 Tech.
Nice.......I already did mine, but I saw all your other videos so why not.....The tool I bought to compress the springs sucked but you had a nice one. The only thing I did different was I turned the engine to TDC on each cylinder as opposed to the air hose method. With my luck I would have a power outage...all good though....
St. Jude Donor '21
I just did the drivers side, Just have to remove the fuel line and then the valve cover can come off. Took about 1/2 the time as the passenger side as with anything, you get the hang of it.. Clutch is next....
https://www.youtube.com/watch?v=SnAdlsSYspM&t=1s
Thanks,
Ken
Thanks,
Ken
St. Jude Donor '21
Good question and I should have put it in the video but I forgot.
This is a 2003 LS1 with 85k miles and I have been revving it to 5900 for 5 years and recently to 6500 for about 4 months (when I added the supercharger).
I have read a lot about the stock push rods being weak and bending so I rolled each of them on a flat surface and all of mine were perfectly straight.
The upgrade to LS6 valve springs is not a huge increase in spring rate (over stock) and I believe the LS1 and LS6 pushrods are the same part # so I am hoping they will be fine. If not, I will replace them. Also, some have said it is good to have them bend if there is an incident vs a super strong pushrod taking something else out.
That theory on the pushrods is wrong... You always want as close to ZERO Deflection as possible in your valvetrain..
IF you still have this project apart;.... Replace the factory pushrods with some aftermarket upgraded units !!!You don't have to go crazy with
stock like cam profile, but the stock ones are OK for bone stock applications.. You are beyond that with your SC
Toys4Life C5 (03-02-2019)
St. Jude Donor '21
Since-
- I have the stock cam and;
- the LS6 shares the same pushrod as my LS1 and;
- the LS6 comes with a more aggressive cam and higher RPM limit
Thank you in advance.
This is the scary part of watching YouTube videos, no way to know if someone really knows what they're telling you is right...
St. Jude Donor '21
Agreed. If it is an engine component or something unfamiliar, I will typically consult a manual and watch a couple of the better videos I can find. If I find a discrepancy, I hone in on the discrepancy until I am satisfied.
St. Jude Donor '21
Been revving to 6500 RPM's for over a year since the LS6 spring swap. Not saying the parts selection and procedures I went with are the only way, but I can say it has worked for well over a year with no issues.
If something was going to fail (like stock pushrods) I think they would have by now.
Toys.
