Rockers with trunion upgrade question..video inside
Old Feb 5, 2019 | 07:29 PM
Vette2lo's Avatar
Vette2lo
Default Rockers with trunion upgrade question..video inside
I had bought a set of rockers of a member and just got to install one side and noticed that one of the rocker C clip spins freely whereas the rest they are pretty stiff and tight.
Womdering if its something I should be concerned about or it’s normal?
Excuse the the loud grinding noise.
Old Feb 5, 2019 | 08:13 PM
StingrayRebel's Avatar
StingrayRebel
as long as it's in the groove and it isn't broken you should be fine... it's possible they opened it up too much when installing it, you could take it off and carefully close the clip a bit so it fits tighter if you can't get the thought of it being loose out of the back of your mind
Old Feb 5, 2019 | 08:17 PM
bwill03z's Avatar
bwill03z
Is that the BTR trunnion kit?
Old Feb 5, 2019 | 08:36 PM
Vette2lo's Avatar
Vette2lo
Yes it’s BTR
Old Feb 6, 2019 | 10:26 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Although the video isn't quite that clear, to me, it looks like the spring clip is a little "stretched out". It's not a big deal to replace the clip, so that's what I'd do.
Old Feb 6, 2019 | 05:41 PM
Vette2lo's Avatar
Vette2lo
i guess I’ll do that to have peace of mind. Any heads up on where to get the clip?
Old Feb 6, 2019 | 05:50 PM
leadfoot4's Avatar
leadfoot4
I doubt that a Lowes or H-D would have anything like that, but you never know. Is there a Graingers, Fastenal, or other similar hardware distributor near you?
Old Feb 9, 2019 | 07:27 AM
Vette2lo's Avatar
Vette2lo
I think there’s a fastenal I’ll google it out. I appreciate it thanks!
Old Feb 9, 2019 | 09:26 AM
StingrayRebel
https://www.briantooleyracing.com/si...iner-clip.html
Old Feb 12, 2019 | 03:37 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
I'd give BTR a call, I honestly don't know if that is a problem. BTR has always been helpful and you might even get Brian on the phone.
To Rockers with trunion upgrade question..video inside
