Tapping/Slapping Noise under car
Full aftermarket exhaust (longtubes, midpipe, bb bullets)
Past 2-3 months, my C5Z has been having intermittent tapping and/or slapping noise under the car. It does not sound like metal to metal contact. It can do it sitting still at idle, or while moving. Clutch in or out, doesn't matter.
It really feels like a belt has broken and just slapping away on something, but both belts are intact and working.
Increasing engine RPM does not effect it, so I don't believe its valvetrain chatter, or engine internals.
I can feel it thru the pedals and floor.
I have placed my hand on just about every suspension part that I can reach and don't feel anything loose.
I fear it may be time for a clutch, or maybe a throwout bearing, but just unsure. Or maybe torque tube issues. It's definitely coming from the front of the car.
Exhaust feels tight and secure (except for the little movement it requires from motor vibration/pulsing).
Tires are in good shape, all brake components are secure.
Replaced sway bar end links a month ago for general maintenance and installed new lowering bolts.
FR wheel bearing has been replaced, FL bearing feels secure (no play from 12-6 oclock positions), but I read in another thread that bearing could still go out without any play? No grinding or clicking noises.
I'm really at a loss on this one. Any suggestions would help.
Torque tube?
clutch?
Engine mounts?
My started went out a week after I started this thread. After dropping the passenger side exhaust (i have longtubes), install the new starter, and then bolting everything back up, I noticed the driver side exhaust had backed itself off at the longtube-cat joint. So I put it all back together.
After driving the car for the past few weeks, I realized I don't hear this slapping noise anymore.
However, today, I had a spark plug wire come loose. It started off as a intermittent miss-fire, but then quickly just became a dropped cylinder all together, just driving on 7. I could hear that slapping noise again, only more aggressively. I knew it had to be the exhaust slapping the tunnel as the engine was running rough due to only running on 7 cylinders. After popping the plug back into place, the motor ran smooth, and the slapping noise under the car went away.
So, process of elimination, the original noise was the exhaust hitting the tunnel under the car.
