Traction control warming up readinf
Old Feb 8, 2019 | 10:07 PM
Danl1986's Avatar
Danl1986
Default Traction control warming up readinf
As post states. I picked my 99 Vette a convertible with 6 speed trans up from the shop that installed my BTR cam and new ls6 manifold. After I got it and drove a few feet the display showed traction control warming. I was told it wil go off from the shop after I drive for a bit but it never did. After driving for 15-20 minutes the light comes on the dash and it read service stability system. It has never given me these type of issues. Once I turn off the car, light is off and it’s fine. Drive a few ft and it does it all over again. Thank you in advance
Old Feb 8, 2019 | 11:18 PM
1999corvettels1's Avatar
1999corvettels1
Is your battery fully charged?
Old Feb 9, 2019 | 07:38 AM
Danl1986's Avatar
Danl1986
Yes battery is fully charged. I’ve driven the car probably another 500 miles since the cam. That includes about 3 weeks of DD it.
Old Feb 9, 2019 | 08:59 AM
73Corvette's Avatar
73Corvette
How do you know the battery is fully charged?
Old Feb 9, 2019 | 09:10 AM
flyingmfrc's Avatar
flyingmfrc
2020 C5 of the Year Winner- Unmodified
Low battery is what everybody told me too. Clear the messages off your dash. Take the car out on a back road, slam on the brakes at about 60 a couple times. It frees up the IBCM piston. That worked for me. Haven't had the message since. Now I do that ocassionaly to exercise that system. Can't hurt to try it.
Old Feb 9, 2019 | 10:40 AM
Moved to C5 Tech.
Old Feb 9, 2019 | 08:26 PM
Danl1986's Avatar
Danl1986
Wouldn’t the battery be charged enough to not cause issues if I had daily driven it for a few weeks without any low battery starting problems ? I have the battery out now for winter storage and it goes in the trickle charger in my shop every 3-4 weeks for the day.
Old Feb 9, 2019 | 09:35 PM
1999corvettels1
With a voltmeter, with battery ground disconnected (or both cables disconnected) are you getting 12.7-12.9 volts?
Yes you could have enough charge to crank the engine over, but be weak enough to cause electric gremlins, even though it sounds weird.
Everytime I've had a glitch or gremlins on mine, battery is 12.4 or lower, trickle charge until normal voltage and the messages go away.
Old Feb 9, 2019 | 10:11 PM
Danl1986's Avatar
Danl1986
I’ll give it a shot! Thank you
Old Feb 10, 2019 | 12:19 AM
Rexde1's Avatar
Rexde1
Low battery causes all sorts of warnings. But I was getting the same warnings when I started out with the wheels turned. Someone else mentioned that and it seemed to be true.
To Traction control warming up readinf
