cranking without starting
Old Feb 10, 2019 | 12:25 PM
dickgi's Avatar
dickgi
Default cranking without starting
I don't want my 03 C5 Z06 to start but to just turn over. I have heard that if you put the gas to the floor and then turn the key that is what will happen. I want to do this after an oil change or the first start of the spring to build up oil pressure first. Can anyone confirm this operation?
Old Feb 10, 2019 | 12:47 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Yes !!...it’s called a “clear flood crank”...it inhibits injection pulse...just keep the pedal to the metal and the engine will only crank.
