low coolant warning??
Old Nov 1, 2002 | 07:21 AM
abraham's Avatar
abraham
Default low coolant warning??
why would it come on and my coolant level looks fine. The car is not running hot or anything?
Old Nov 1, 2002 | 07:29 AM
batsallover's Avatar
batsallover
Default Re: low coolant warning?? (abraham)
Mine started doing that when on inclines, like on hills and steep driveways. I suggest you fill the reservoir up to where the black plastic part of the tank begins. I filled mine up just beyond that and the low coolant light stop coming on intermittantly. Mine started coming on only after I change to my 160* thermostat. Hope this works, good luck. :cheers:
Old Nov 1, 2002 | 07:34 AM
abraham's Avatar
abraham
Default Re: low coolant warning?? (batsallover)
I just changed to than also. Well about 2 or 3 months ago. Thanks for the input.
Old Nov 1, 2002 | 10:12 AM
1999 White C5 Coupe's Avatar
1999 White C5 Coupe
abrraham,
There was a TSB issued for this problem. The 1997's involved replacing the surge tank/sensor with a second design part. The 1998 and 1999 were to have the second design tank, but it had to be repositioned.
Good luck. Your dealer should be able to look up the TSB for you.
Old Nov 2, 2002 | 06:28 PM
lostsoulny's Avatar
lostsoulny
Default Re: low coolant warning?? (1999 White C5 Coupe)
just fill it a bit, I got it in the past, filled it a bit and haven't seen it in almost a year :cheers: As mentioned above, an incline can cause the coolant to become "uneven" therefore registering a false low coolant reading
To low coolant warning??
