MAF HOUSING
Old Nov 1, 2002 | 04:53 PM
skidmarc's Avatar
skidmarc
Default MAF HOUSING
Ok so looks like I will not be putting the relocated/recalibrated MAT on my 99 since the general consensus is detonation and waste of $..........but what about the MAT housing upgrade with airfoil????? Good or no?? Any input would be great ...thanks guys
Marc
Old Nov 1, 2002 | 05:54 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
Default Re: MAF HOUSING (skidmarc)
what do you have now? :cheers:
Old Nov 2, 2002 | 01:17 AM
chuckster's Avatar
chuckster
Ported MAF's are great only if you can tune for them..i.e MAFT
They generally lean you out so you need to compensate by reclibrating the system by adding fuel.. The maft will do that..
Or of course custom programming...like ls1-edit or predator
Old Nov 13, 2002 | 11:11 AM
skidmarc's Avatar
skidmarc
Default Re: MAF HOUSING (chuckster)
Chuckster....I have the MAF housing upgrade with airfoil......I do not know if that is considered ported???
Old Nov 13, 2002 | 11:13 AM
chuckster's Avatar
chuckster
Yep it's ported...
Most likely the one from Breathless Performance...
To MAF HOUSING
