Using .120 cometic head gaskets.
Old Feb 27, 2019 | 09:42 PM
Derek Hall's Avatar
Derek Hall
1st Gear
Default Using .120 cometic head gaskets.
Hey new here first time posting and I was hoping someone here had some experience with this. 2000 Corvette LQ9 iron block forged bottom end. Cam has .637/.637 lift valves hit at 5750-6000 rpm. The shop im working with had me order .120 head gaskets to lower my compression to the 8 to 1 ballpark and provide more valve to piston clearance and .120 intake gaskets. I dont think the factory intake manifolds will bolt up due to the bolt holes being spread apart. Has anyone ran into this or know of an intake manifold that will work? Looking at twin turbos for the engine or possible a twin screw blower.
Old Feb 28, 2019 | 05:48 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
8:1??? That’s rediculously low unless you’ve only got shitty gas where you are.
Also, are you saying that your valves already hit the pistons with that cam? If so, are you sure it’s degreed properly?
Old Mar 1, 2019 | 03:14 PM
FreeC5inAZ's Avatar
FreeC5inAZ
If your valves hit at only upper RPM then you have valve float. If they were hitting due to clearance, it would happen at all RPM.
Find a new shop.
Old Mar 2, 2019 | 09:00 AM
JHrinsin's Avatar
JHrinsin
With that much lift, you are going to need fly cut pistons (most likely aftermarket forged units, not sure if -2cc will be enough) and some stiffer valve springs, most likely something like Comp Cams 26926 duals.
You need to fine yourself a more knowledgeable engine builder.
Old Mar 3, 2019 | 10:56 AM
mykream's Avatar
mykream
As everyone else has said, your engine builder is an idiot. I would not give them anymore of your money. There is no reason to have an 8:1 engine, and a 0.120" Gasket?!?!?! That is ridiculous.
Old Mar 11, 2019 | 02:41 PM
67Ranger's Avatar
67Ranger
You should run different pistons with a thinner gasket. That much quench area is not a good way to get compression down. If the piston to valve clearance isnt enough, cut the pistons. You shouldnt have intake manifold fit issues, but there is a decent chance that will cause worse performance than doing it right.
Are you trying to reuse a set of pistons you already had, or did they recommend these pistons? Also, what is your piston to deck clearance?
Old Mar 11, 2019 | 09:05 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
Doesn’t seem like the OP gives a **** about our opinions....
Old Mar 12, 2019 | 09:29 AM
VFR RC46's Avatar
VFR RC46
If you make valve to piston contact at 6000, I am pretty sure you're going to damage/break some things....
To Using .120 cometic head gaskets.
