Steering rack removal tip
Old Mar 4, 2019 | 07:24 AM
R1-Addict's Avatar
R1-Addict
Default Steering rack removal tip
So I spent the weekend pulling the motor down in preparation for the cam and heads install. All went well other than the coolant disaster all over the place. I read how a lot of people steuggle getting the rack out. Some use pry bars and other lower the cradle. I simply removed the two bolts holding the ABS module, moved it slightly and the streering rack pulled right up with no issues. Took about five minutes,
Old Mar 4, 2019 | 09:35 AM
Josephu's Avatar
Josephu
My 98 has the ABS controller behind the differential. Lots more room up front. Sometime or other, I think that they changed the cradle to give the rack more clearance for removing. Some have to drop it....and some dont. I did.
Old Mar 4, 2019 | 07:18 PM
scorpiofox69's Avatar
scorpiofox69
Video please!!!! I have to see this if you took one, or still can!
Old Mar 5, 2019 | 06:52 PM
tabbruzz's Avatar
tabbruzz
No way that would work when I did mine...
Old Mar 5, 2019 | 07:06 PM
pjdbm's Avatar
pjdbm
I had to lower the cradle and use a pry-bar (carefully) to get mine out
Old Mar 5, 2019 | 09:38 PM
Mr. Black's Avatar
Mr. Black
No Hostility Be Happy
I really didn't think much about my ABS pump being rear mounted and how much easier it made it. I had my rack out in minutes also (probably 20 minutes taking it easy) Chock that up to a rare plus to owning an early C5.
To Steering rack removal tip
