I happen to notice now a curious sound my engine makes under decel during that moment you clutch-in and upshift in high RPMs. Right at the moment the engine load is relieved during the upshift and RPMs drop, engine does this snarling/snoring sound. Wanted to know how many people experience this with their LS's. I only notice now that it's cammed and has long tube headers. I'll later upload a onboard video of a pull demonstrating this.
Pretty sure it's normal. Ive heard the same noises from track videos where mic's are mounted near the exhaust. The moment of decel causes kind of a floppy/snory kind of sound, even for an LS7.
Wow you’re right, I guess I just never noticed before. A quick YouTube search was all it took.
Most all the times when I tune a cammed LS engine I always DELETE the DFCO system
"deceleration fuel cutoff " When the DFCO is activated on decel it shuts the fuel OFF and creates either a popping exhaust sound or a gurgling sound Deleting DFCO allows small amounts of fueling at decel and usually cleans up that annoying noise
ALSO Does your car have the STOCK H-Pipe? If so changing it over to an X-pipe also changes the decel sound as the stock H pipe only has about a 3/4" hole between left and right sides An X pipe is more open between left and right and the balance of exhaust equalizes better again eliminating any drone or "motor boat" gurgle Plus it can add 2-5 HP !!!!!!!!!!!!!
