Won’t start !
Old Mar 7, 2019 | 02:46 PM
msandym's Avatar
msandym
Default Won’t start !
Hi , I don’t post much , I don’t have problems , BUT yesterday I left lights on , needed a jump to start . Today , went out , came back and car won’t start , electrics work , but nothing when I turn key to start , no sound no nothing . But it dings and radio works even with key out . Ignition switch ?
Old Mar 7, 2019 | 03:10 PM
rrwirsi's Avatar
rrwirsi
IMHO, sounds like the battery to me. If you have a charger, fully charge the battery and try again. If still no start after charging, take it to one of auto stores for testing.
Old Mar 7, 2019 | 03:14 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
these cars don't like jump starting !!!!! FWIW agree check bat !!!
Old Mar 7, 2019 | 03:17 PM
Jackie N's Avatar
Jackie N
Obviously a weak battery. Test, charge, replace if still low.
Old Mar 7, 2019 | 03:18 PM
Moved to C5 Tech.
Old Mar 7, 2019 | 03:19 PM
mmo24's Avatar
mmo24
definitely sounds like your battery isn't charged enough. As stated charge it fully overnight and try again.
Old Mar 7, 2019 | 03:29 PM
STRMLNE's Avatar
STRMLNE
Replace battery
Old Mar 7, 2019 | 04:03 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
As others have mentioned it's always a good idea to have your battery load tested first for any starting malfunctions and go from there. Full charge around 12.66 volts. If you might think it's an ignition switch and you have and know how do use a multimeter connect the red lead to battery positive and the black lead to one of two test points on the CRK fuse #14 (IP Fusebox) and then PCM fuse #16 (underhood fusebox)....try to start the car and read what the multimeter reads on each fuse...you will be measuring the "voltage drop" across the ignition switch...should not be more a few tenths of a volt !!
Old Mar 7, 2019 | 04:06 PM
msandym's Avatar
msandym
Thanks . I’ll start there !
Old Mar 8, 2019 | 02:51 PM
msandym's Avatar
msandym
Success ! Been here long enough but the key thing threw me off . Thanks all !
To Won’t start !
