Error codes out the ass!
Old Mar 16, 2019 | 06:48 PM
R1-Addict's Avatar
R1-Addict
Default Error codes out the ***!
I just installed TSP Torquer v2 cam and PRC 225 heads, I sent my ECU off to Mailordertuner.com (former TSP tuner) and reinstalled. Car runs fine but I am now getting about 20 codes, 16 of them are BCM communications errors and I am also getting right and left DCM errors codes as well. Looks like I need to call them on Monday!
Old Mar 17, 2019 | 01:45 AM
BigGun's Avatar
BigGun
Sounds like a problem with serial buss line. Clear them and see what comes back. Probably an easy fix once you locate the problem. Are you sure the battery is in good shape after all that work?
Old Mar 17, 2019 | 08:57 AM
R1-Addict's Avatar
R1-Addict
The battery died once after the upgrade becuse I left the ignition on. It is showing 14.5v when car is running. I do know a failing batter can cause issues. The only thing changed electrically was removing the ECU and getting it programmed and reinstalling.
Old Mar 17, 2019 | 02:26 PM
BigGun's Avatar
BigGun
Wouldn't hurt to do a load test just to be sure. What codes come back after you clear them and restart?
To Error codes out the ass!
