C5 stuck horn
Old Mar 17, 2019 | 08:40 PM
Suipakpaikungfu's Avatar
Suipakpaikungfu
Default C5 stuck horn
Went to make a left hand turn and was cut off.... Sounded the horn and the darn thing stuck! Any help or ideas on the fix fir this? I pulled the fuse for a short term fix.
Thanks in advance!
Old Mar 17, 2019 | 11:43 PM
BigGun's Avatar
BigGun
Most common problem is the horn membrane in the steering wheel. The membrane is about 55.00-65.00 bucks and you will need to install it yourself or find someone to do it for you. The dealer will only replace it with the air bag and that gets into big bucks. Google has lots of video and how to if you search.
Old Mar 18, 2019 | 12:44 AM
GCG's Avatar
GCG
Take a look at the circuit. Check the horn relay first, but it's usually the horn membrane.
You can get it here and replace it yourself by following
Old Mar 19, 2019 | 02:17 PM
Suipakpaikungfu
Thanks! Looks like something I can do. 2 questions: Do you know if the airbag has to be deactivated in some way before removal?
And do you know what size trox bit is used to remove the screws holding the airbag to the steering wheel?
Old Mar 19, 2019 | 02:23 PM
GCG's Avatar
GCG
As the 1st step in the video shows: disconnect your battery and wait a few minutes before beginning to work
Old Mar 19, 2019 | 02:57 PM
Suipakpaikungfu
Anyone have a part # for the horn membrane or know where I can get one? As BG said, I went to the dealer and they don't even have a separate PN for it....
I'd have to buy the entire Airbag unit which I do not need.
Old Mar 19, 2019 | 03:02 PM
GCG's Avatar
GCG
I gave you a link to get the membrane on my original post (click on "You can get it here"). I'm not home, but I'll try to get you the torx sizes later.
Old Mar 19, 2019 | 03:03 PM
Robrote's Avatar
Robrote
You'll want to follow the instructions on removing the steering wheel (when removing the airbag). Disconnect the battery, wait, disconnect the 2 yellow connectors under the dash next to the column. Unbolt the airbag, remove the two connectors behind the bag. It's a good idea not to accidently send a static electric shock to the connectors on the back. Maybe a piece of black tape to prevent that from happening.
I did this membrane job a couple weeks ago. Not hard, just take your time.
Old Mar 19, 2019 | 03:36 PM
Suipakpaikungfu
GCG, thanks! Missed the link, ordered and on way. Please let me know if you find the correct trox bit size.
Old Mar 19, 2019 | 03:40 PM
Robrote's Avatar
Robrote
It's a T30. You'll need something with a 3 inch shank to fit in to the opening.
Old Mar 20, 2019 | 10:06 AM
Suipakpaikungfu
Thanks!
Old May 22, 2019 | 04:08 PM
Suipakpaikungfu
Fixed, thanks for the help!
To C5 stuck horn
