oil pressure.
Old Mar 18, 2019 | 08:50 PM
jarv33's Avatar
jarv33
Default oil pressure.
today as I was driving my 02 vert base model I was checking the gauges and oil pressure on the dial peg out at 30lbs. digetal read 130lbs.. car was and still is running great.oilwas fine,car not heating up so what went wrong? any help will be appreciated.thanks
Old Mar 18, 2019 | 08:52 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
bad oil sending unit ???? common issue !!!!
Old Mar 18, 2019 | 09:20 PM
DDaaryl's Avatar
DDaaryl
Common issue well documented on this site. There are some short cuts to change the sending unit if you are creative and have tools.
Old Mar 19, 2019 | 12:55 AM
Moved to C5 Tech.
Old Mar 19, 2019 | 06:12 AM
wscott62893's Avatar
wscott62893
Do yourself a favor and buy a sensor relocation kit for when you do the job. That way the next time the sensor goes bad (because it will), you won’t have to remove the intake manifold.
Old Mar 20, 2019 | 11:45 AM
jarv33's Avatar
jarv33
Thanks for your help, kinda new at this stuff. this forum is really great, thanks again.
To oil pressure.
