Dreaded washer pump issue
Old Mar 19, 2019 | 06:26 PM
wifes97C5's Avatar
wifes97C5
Default Dreaded washer pump issue
I tested the pump straight to the battery and it works, I used a voltmeter on the plug and I have 12 volts when the button is pressed but when I plug it in and test the voltage on the wires when it is pressed the voltage spikes then immediately goes to zero??? any ideas
Old Mar 22, 2019 | 02:42 PM
wifes97C5's Avatar
wifes97C5
Beuhler....
Old Mar 22, 2019 | 03:13 PM
1999corvettels1's Avatar
1999corvettels1
What button are you pressing?
Old Mar 22, 2019 | 06:25 PM
wifes97C5's Avatar
wifes97C5
The washer fluid button in the stalk
Old Mar 22, 2019 | 06:50 PM
1999corvettels1
Oh, Haha! I had a brain fart and thought you had an electric water pump that you were having issues with.
Old Mar 22, 2019 | 06:58 PM
crf450x's Avatar
crf450x
You have a bad connection somewhere. My guess is in the multi function switch but could be anywhere. A wiring diagram would be helpful.
Old Mar 23, 2019 | 04:29 PM
wifes97C5's Avatar
wifes97C5
The wire right at the pump was had been hot enough that it actually turned light brown from pink. I'm not sure what caused that but I replace that section of wire with no effect. The wire seems to go towards the front of the car and then at some point turns around to head back towards the interior. I am going to purchase a new OEM switch install that see if that is the issue and if necessary wire it directly from the switch through the firewall to the pump. I have no other ideas on what it could be or what to do.
To Dreaded washer pump issue
