Supercharged C5 Clutch Install - Starting NOW! Thoughts - tips?
Plans are to -
1. Go with Monster LT1-S kit (purchasing from Tick Performance on sale)
2. Mark and note the location of the flywheel on the crank and PP on the flywheel and have them Match balanced locally so the Monster has the same external balance as the stock setup.
3. Replace torque tube couplers (mine have 80k on them).
4. New GM slave cylinder
5. Purchase and install a quick bleeder kit - any opinions about which one is best?
6. What a I missing?
7. Anyone need any video of any part of the process??
Thanks!
Ken
I use the Tick remote bleeder kit, works fine. It has a speed bleeder, so once you open the valve its a 1 man operation of just pumping the pedal--no gripes
Flywheel holder tool so you can torque bolts without engine rotating (if you dont have one)
Rear main seal?
Clutch alignment tool, probably comes with one? Mine didnt for some reason IIRC
That's all i can think of right now off hand.
links:
Absolutely, absolutely match-balance the monster clutch kit. I had a bad experience with this. You must take it to a machine shop and get it balanced properly. Often this will be a zero-balance, but do not trust that the clutch you get is zero-balanced brand new.
Torque tube couplers, yes, but also the bearings. If you are doing it DIY, you probably want OEM bearings. If you are paying labor, it may be almost the same price to just buy a new prop shaft with new couplers and bearings installed on it.
You can get Monster's clutch kit with the clutch, including the pilot bushing w/ alignment tool, the throw-out bearing, the slave cylinder. And their bleeder. I got the speed bleeder ($50). Technically a "one man unit" as it has a check valve. Haven't tried it yet.
Do NOT go for an adjustable master cylinder, as per Monster's recommendations (via email). You can make it work, but they do not recommend it. With that said, the previous owner installed either an adjustable one or just one with a fat bore, and the shop doing the install checked and said it's set up fine to work fine. We rolled the dice on that and so far no issues. If issues develop, well, that's the cost of not wanting to do the work and spend the money to install a stock unit.
I got their standard flywheel, which is lighter than stock, but I should have gotten their lighter unit. Strongly consider their lighter unit unless you're a really slow shifter
There's a bunch of other stuff you may want to do at this time. I don't have a full list handy, but ...
- Check engine and trans mounts. Replace if needed. No new OEM parts exist, so you will not have the most fun time figuring out which replacement you want.
- Check rear main. Don't replace it unless you need to is the advice I got.
- Probably easy to do new trans/diff fluid at this time.
- Also, in addition to inspecting the rear transaxle for leaks and stuff, clean it all nicely so that if something leaks in the future it's easier to spot.
- Inspect control arm bushings for excessive wear, play, or them kinda coming out of the arms.
- Consider whether you want to take this time to upgrade the prop shaft. You can go for a carbon one.
- Consider whether you want to take this time to upgrade the couplers. You can go for solid couplers over rubber ones. They're no longer a wearable item and are great for race car stuff but not necessarily great for the street. You would also need to carefully machine solid couplers - they do not come perfectly matched to your setup from the aftermarket manufacturer(s).
- Consider whether you want to add a diff/trans brace. Really easy to do it with the drivetrain out on the ground.
- If you need any R&R for the trans/diff, now's a great time to send that sucker to a shop. Or if you want upgrades.
- Consider whether you want to replace the tunnel plate with one that is fatter (stiffer) and/or has heat shielding on it.
- If you dropped the exhaust headers out, now's a good time for nice new MLS gaskets.
Definitely stock bore / OEM master cylinder. Twin disc already makes the engagement slipping window small, larger bore makes it way worse. I had the Tick unit initially. I switched over to a standard size bore (3/4" I think?) tilton and it was back to OEM like and much better.
I personally recommend the heavier/standard flywheel. With the supercharger and lower moment of inertia LT1-S clutch/pressure plate... my revs drop like a rock between shifts, even with AC off. I'm guessing yours is already like this even with stock clutch etc. If you have a cam etc too, this should help it catch idle and help idle stability, etc.
Recommendations on torque tube bushings and best place to get them? I have seen some comments not to use the Dormans but not sure why....
That machine work I mentioned is what you need to get rid of most of the vibration it'd add.
That said, yes, the solid TT couplers will add NVH to your system. No doubt about it.
And yeah, the rubber couplers are, well, rubber. Time and engine-hours will cause them to degrade. After 15 or 20 years, there is no doubt you should change them out if you go through the work of dropping the torque tube down.
I spoke to a tech from Doug Rippie today. He told me he has done countless C5 Clutches without match balancing to the existing clutch and pressure plate and has not had any come-backs with vibration. How was yours - did you notice any vibraiton after the install that was not there before? Maybe this is a much smaller problem than I am thinking and I should just toss my new monster in too....
