Code P0300
Old Nov 3, 2002 | 06:21 PM
tabbruzz's Avatar
tabbruzz
Default Code P0300
I keep getting this code. The check engine light comes on, but when I check the codes they say H........I get no C codes. I know its a misfire code but my wires and plugs are pretty new and seem ok. Any thoughts or advice.
Thanks,
Tony
Old Nov 3, 2002 | 08:02 PM
kh24's Avatar
kh24
Default Re: Code P0300 (tabbruzz)
Have you added headers recently? The heat from them can cause a misfire. I put mine on myself and cracked a plug doing it. I got the same code and couldnt figure out why untill my dealer saw the plug was cracked. I bought new wires too to help from the heat. I suggest replacing the plugs and go to wires next if that doesnt help. :cheers:
Old Nov 3, 2002 | 09:55 PM
tabbruzz's Avatar
tabbruzz
Default Re: Code P0300 (kh24)
Yes I did just put headers on and I figured it was related. My car was prone to random misfires prior to the header install, but a code was never set. I guess I will look into better wires and new plugs. I currently run the NGK55s and stock wires....
Old Nov 4, 2002 | 12:32 AM
kh24's Avatar
kh24
If the plugs were left in during the header install, like i did on mine, then the header might have hit into a plug and cracked it. I also would only get history codes...i got one current one when driving and i checked it right when the engine light came on. When i got new plugs i put in the NGK 55s and MSD wires and have not had one misfire since then. I think the plugs and wires will straighten you out. :cheers:
Old Nov 4, 2002 | 03:48 AM
tomdcarguy's Avatar
tomdcarguy
From: A.M.R. Pound for Pound-Fastest Stock Bottom LS1 9.1x 10psi
Hey Tony....Maybe you have some cobwebs in the spark plug wires causing the misfire!!! :lol: :lol: :lol: :lol: :lol:
Old Nov 4, 2002 | 05:01 AM
pkmoose's Avatar
pkmoose
Cruise-In III Veteran
Default Re: Code P0300 (tomdcarguy)
:lol: Tony, you have to drive the car to get misfires :smash:
Old Nov 4, 2002 | 02:00 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Default Re: Code P0300 (pkmoose)
After installing a new cam, I starting getting the check engine light and the misfire code. I had to raise the in gear engine idle. It takes about three misfires before the check engine light comes on.
Old Nov 4, 2002 | 10:33 PM
tabbruzz's Avatar
tabbruzz
Very funny.....Maybe its my damn mechanic at Surf that screws everything up....
Old Nov 4, 2002 | 10:53 PM
kh24's Avatar
kh24
Yeah i let him screw up my car all the time :lol:. Tommy was the one who found the cracked plug on my car.
To Code P0300
