PCV mod works!!! Pic inside...
Old Nov 4, 2002 | 12:15 AM
C5-VERT's Avatar
C5-VERT
Cruise-In IV Veteran
Default PCV mod works!!! Pic inside...
This is what is collected after 2 weeks or so of normal driving(maybe 5-6 wot quick runs) on my new Big Bore engine.
I used the filter from Pep Boys which allows me to open the drain valve from the bottom very easily.
[Modified by C5-VERT, 12:11 AM 11/4/2002]
Old Nov 4, 2002 | 12:32 AM
intel55's Avatar
intel55
Default Re: PCV mod works!!! Pic inside... (C5-VERT)
where did this new iteration of the PCV mod come from?? Any websites that show how to make this? I like that lil drain.
thanks :cheers:
Old Nov 4, 2002 | 12:36 AM
427_Roadster's Avatar
427_Roadster
:confused: Probably a dumb question but, what's in there gas, water? That would go back into the block if the trap wasn't there?
Old Nov 4, 2002 | 12:49 AM
C5-VERT's Avatar
C5-VERT
Default Re: PCV mod works!!! Pic inside... (427_Roadster)
Here is a link with plenty of info and how-to instructions >> Click Here
BTW, that is oil in the valve. Normally that oil would be routed back into your intake manifold to be burned during combustion. It really makes a mess inside the intake manifold and intake runners.
[Modified by C5-VERT, 11:50 PM 11/3/2002]
Old Nov 4, 2002 | 01:03 AM
427_Roadster
:cheers: Thanks! Usedfull mod! Gonna give it a shot. Wonder if that would help at all with the carbon buildup on the exhaust tips?
Old Nov 4, 2002 | 01:04 AM
C5-VERT's Avatar
C5-VERT
Probably will not help much with carbon built up. I think that is mostly due to a rich condition or unburned fuel. Can't hurt though! :cheers:
Old Nov 4, 2002 | 01:08 AM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
Oil being consumed into the intake like that really lowers the octane of your a/f mixture, which then promotes detonation, carbon buildup, etc.. This mod is a very good idea, especially for stroker and heads/cam cars.. I did it on my car and have stopped a ton of oil from entering the intake manifold.
Old Nov 4, 2002 | 01:11 AM
ddawson's Avatar
ddawson
Just to check, Does the air flow from the covers to the intake?
I ask because my filter also has the arrow on top for the direction of flow but after a few days it's still empty.
Old Nov 4, 2002 | 01:38 AM
gojo's Avatar
gojo
Default Re: PCV mod works!!! Pic inside... (ddawson)
The arrow should point to the intake. I've had mine on for two weeks and no oil. Just a little yellow on the filter. When I did the mod, the line at the intake was a little oily. It's now clean. Have any changes been made to the later models that make this less of a problem?
Here is what mine looks like. http://www.shutterfly.com/osi.jsp?i=...21b308c82425a0
[Modified by jfpilla, 12:42 AM 11/4/2002]
Old Nov 4, 2002 | 02:16 AM
C5-VERT's Avatar
C5-VERT
Default Re: PCV mod works!!! Pic inside... (jfpilla)
I've had mine on for two weeks and no oil. Just a little yellow on the filter. When I did the mod, the line at the intake was a little oily. It's now clean. Have any changes been made to the later models that make this less of a problem?[/url]
Well I also have a big cube engine w/ alot of mods which may increase crankcase pressure causing more oil accumilation. And driving habits have alot to do with it.
[Modified by C5-VERT, 1:17 AM 11/4/2002]
Old Nov 4, 2002 | 02:40 AM
kp's Avatar
kp
If I drive my car normally I seldom see any oil in there. When I beat it up it starts to accumulate. I also noticed once it gets to the bottom the filter it seems to stop there so I try to keep it drained.
If its installed properly and you dont see a lot of oil thats a good thing..
Old Nov 4, 2002 | 08:05 AM
AllCammedUp's Avatar
AllCammedUp
Killer. I'm going to do this to my car when I get it all back together.
One quick question. You mention being able to drain yours quickly. However, the other threads I've seen on this subject say to put permatex or something similar on that bottom draincock so that the pressure difference inside the filter doesn't cause that drain to open on its own.
Did you leave yours 'stock' and unsealed?
Old Nov 4, 2002 | 10:13 AM
knkayotte's Avatar
knkayotte
Did the mod 2 weeks ago, no oil until this weekend. Then I had about a thimbles worth.
For the $ and time involved, everyone should do this.
Later, Keith :flag
Old Nov 4, 2002 | 05:09 PM
C5-VERT's Avatar
C5-VERT
Default Re: PCV mod works!!! Pic inside... (AllCammedUp)
That because I am using a different style of valve. Go to Pep Boys to the the valve that I used. I think it was under $20 or so.
Old Nov 4, 2002 | 08:06 PM
gojo's Avatar
gojo
Default Re: PCV mod works!!! Pic inside... (kp)
I guess I'll have to drive my car harder. Not a problem.
Old Nov 7, 2002 | 09:02 PM
Bling Bling's Avatar
Bling Bling
Go to pep-boys and go to where they have the air compressors. Look for the filter they says Manual Drain type, look in the back of the filter, it will say weather its Auto or Manual drain type.
It is a great mod and one of the easiest to do. I have a 97 MN6 and after one run I already saw some oil in the filter. It makes me want to clean all the oil out that burned off before I installed the filter!
Old Nov 7, 2002 | 10:02 PM
C5-VERT's Avatar
C5-VERT
Default Re: PCV mod works!!! Pic inside... (Bling Bling)
Or just right click, then left click 'print picture' and take it with ya to pep boys. That would be too easy... :cheers:
To PCV mod works!!! Pic inside...
Old Nov 18, 2002 | 11:23 PM
AllCammedUp
Most excellent, gentlemen. Many thanks! I'm going to PepBoys in the morning to pick this up!
Old Nov 19, 2002 | 12:01 AM
ScreaminDemon's Avatar
ScreaminDemon
Besides pissing off the EPA-***** are there any negative issues with just running a filter on each valve cover and plugging the intake hole? I've heard rumours of needing to run a slight negative pressure in the crankcase with this slight vacuum but I haven't found any evidence to back that up? I've been running this way for some time now...
David
Old Nov 19, 2002 | 01:30 AM
hrdtopv8's Avatar
hrdtopv8
Do you get rid of the PCV valve all together or is it inline with the filter?
:confused: I couldn't tell from the mod pic..
