Sway Bar thump
Old Apr 8, 2019 | 10:56 AM
LTCHAPPA's Avatar
LTCHAPPA
Default Sway Bar thump
I jacked up the rear of the Vette to try to find out the cause of thump noise I was hearing because it was. Driving me crazy. I went over all the bolts that I could get too and found the right side swap bar needed some tightening. Noise gone.
Old Apr 8, 2019 | 11:22 AM
RPGR90s's Avatar
RPGR90s
its good when you find a simple solution.
I replaced all the front and rear sway bar end links and my suspension is quiet as a mouse too.
It only adds to the car's enjoyment
Old Apr 18, 2019 | 08:54 PM
bighank's Avatar
bighank
Default Use teflon tape under the bushings
I changed out the stock sway bars with Z51 bars and wrapped the bars under the bushings with teflon plumbers tape. About 3 layers under each bushing. No squeaks or thuds for about 10 years.
You might want to try it..
To Sway Bar thump
