New Cartek products.
Old Nov 16, 2002 | 05:53 PM
STEALTH C-5's Avatar
STEALTH C-5
Default Re: New Cartek products. (tekhombre)
What cubic inches do you get with the 4.125 bore and 4.00 crank?
Old Nov 16, 2002 | 06:07 PM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
Default Re: New Cartek products. (STEALTH C-5)
That's one impressive looking block.
would look good in my car..
Old Nov 16, 2002 | 10:49 PM
Flyin'Brian's Avatar
Flyin'Brian
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
427 :) here is a nice online calculator for displacement http://www.prestage.com/carmath/calc_cid.asp
Old Nov 17, 2002 | 07:49 PM
STEALTH C-5
Default Re: New Cartek products. (Flyin'Brian)
Thanks,Your car looks mean with the black wheels.
[Modified by STEALTH C-5, 7:53 PM 11/17/2002]
Old Nov 17, 2002 | 08:30 PM
1320crazy's Avatar
1320crazy
wow that block looks awesome :cheers: :cool:
Old Nov 18, 2002 | 02:37 AM
STEALTH C-5
It's winter,the weather SUCKS in the Northeast and I have too much time on my hands right now because I'm thinking about having Cartek upgrade me to a 434Cid when the new 4.155 Darton sleeve comes out,or if I can sell or trade my 4.00 crank and get a 4.125 I'll have a 447Cid and almost a perfectly square motor,combined with a solid roller set up this would be one EVIL LS-1!!!!
Old Nov 18, 2002 | 02:45 AM
STEALTH C-5
Actually a 4.125 bore X 4.125 stroke 441Cid sounds even better,I'll be on the phone with Cartek tomorrow,now if I can only find someone to make a stronger rear end casing and heavy duty driveline parts I'll be all set.
Old Nov 18, 2002 | 03:30 PM
C5_PIG's Avatar
C5_PIG
WOW Mike that sounds like a sick set-up. Will that be the biggest CI you can get. I thought a 436ci was the biggest. What kinda of specs are we looking at with a motor like that? Good Luck in your new project.
Old Nov 18, 2002 | 03:46 PM
intel55's Avatar
intel55
Default Re: New Cartek products. (C5_PIG)
Well you can go to 461!!! At least when the 4.155 bore comes out, which both Ed@LPE and Dave@Cartek should be very soon. I am gonig with a 4.155 bore and 4.125 stroke for a 447. The 461 is with the 4.25 stroke. :yesnod: :cheers:
Old Nov 19, 2002 | 12:09 AM
Sales@MVPAutoParts.com's Avatar
0Sales@MVPAutoParts.com
Former Vendor
Default Re: New Cartek products. (intel55)
461CI? Man, that is insane. :crazy: :crazy: :crazy: I wonder what the rwhp/rwtq on these motors will be. 600rwhp? :crazy: :crazy: :crazy:
Old Nov 20, 2002 | 01:05 AM
STEALTH C-5
Mark,I spoke to Julio and Dave yesterday,I'm staying with the 415.Julio has a few tricks up his sleeve,they'll be trying some new stuff out on my car soon.The limiting factor on the bigger motors over 427Cid is the heads and the LS-6 intake.I can't afford C5R heads and a custom intake right now so it's not worth going bigger,the motor will be choked.
Old Nov 20, 2002 | 03:44 AM
intel55's Avatar
intel55
:D :D
That is why I got one of these :D :D Don't build a "big" block without one :D
Old Nov 21, 2002 | 01:59 AM
  #33
STEALTH C-5
That looks like the same intake Cartek has,if it is,the runners are smaller than the port size on my LS-6 heads and there's not enough material to open the intake runners up to match the heads.Do you know if the company that makes that intake can make it with larger runners?
Old Nov 21, 2002 | 10:53 AM
  #34
Daryl's Avatar
Daryl
Default Re: New Cartek products. (Tuan Le)
Very nice! :)
