Quick dumb question
Old Apr 13, 2019 | 01:50 AM
Rexde1's Avatar
Rexde1
Default Quick dumb question
I’m changing my headlight bulbs. I forgot is it hood up than lights or lights up then hood.
Thanks.
Old Apr 13, 2019 | 05:08 AM
STRMLNE's Avatar
STRMLNE
Thanks.
it doesn’t matter
Old Apr 13, 2019 | 08:45 AM
3sACROWD's Avatar
3sACROWD
It doesn't matter however if you don't want to have any lights on while performing the change, then you have to open the hood and manually raise the buckets. In my opinion, this is the safer method because there is no power controlling the buckets. Otherwise, you can use the light stalk. In that case, turn the headlights on, let the buckets open, then click back to running lights. This will allow the buckets to be up with the headlights off.
If you raise the buckets manually, you don't have to lower them manually. Just turn your headlights on then turn them back off. The car will figure it out and lower them.
To Quick dumb question
