Pilot bearing
Old Apr 16, 2019 | 09:45 PM
skittlenips's Avatar
skittlenips
Default Pilot bearing
Hey everyone, just purchased an LS7 clutch kit and an upgraded ls6 slave cylinder, what pilot bearing should I buy and from where? Thank you everyone
Old Apr 16, 2019 | 11:21 PM
feeder82's Avatar
feeder82
  • GM Part # 14061685 - Pilot bearing
  • Any where you can be sure it's a genuine GM.
Old Apr 17, 2019 | 07:46 AM
Spaggs's Avatar
Spaggs
Absolutely!
Spaggs
Old Apr 17, 2019 | 12:36 PM
mykream's Avatar
mykream
DO NOT USE BREAD OR GREASE OR ANY HYDRAULIC METHOD TO REMOVE THE PILOT BEARING...
That is all.
Old Apr 19, 2019 | 08:00 AM
Simtech's Avatar
Simtech
That is all.
Ok I'll bite. Why not?
Old Apr 19, 2019 | 08:05 AM
mykream's Avatar
mykream
There is an oil galley plug in the back of the crank. If you put too much pressure on it with one of those methods, then you risk pushing the plug farther forward into the crank and causing an oil leak which could be diagnosed as a rear main leak when it's not.
To Pilot bearing
