torque tube bearing question
Old Apr 27, 2019 | 05:05 PM
C5Vette612's Avatar
C5Vette612
Default torque tube bearing question
im trying to replace the bearings in my torque tube ive spent hours upon hours searching and reading all the posts I can find about the process seems pretty easy and straight forward and so far haven't had any issues. Not even with the snap ring everyone seems to dread. the thing I cannot figure out and nobody talks about is the torque specs of the big nut on the rear bearing housing. can anybody help me out here on the torque specs of the nut in this picture, also has anybody drilled and tapped the coupler bolts from 10 mm to 12mm? how did that work out for you? I plan on getting the carbon fiber driveshaft from dss. and just curious if anybody has done this. And while im at it has anybody used the nachi quest bearings or is everybody running the nsk bearings? and does anybody have the part numbers for any of the bearings. I had a thread saved with the numbers but cant seem to find it, if not ill just look at the side of the bearings when I get them out and see what the part numbers are, Thanks
2000 convertible A4 4l60e
Old Apr 27, 2019 | 08:41 PM
Cutlassmaster's Avatar
Cutlassmaster
If you don't have answers by tomorrow morning I will get you what you need. I did my 99 last year at this time. I stayed with the 10mm though and have had no issues. I'm running double the HP than stock.
Chris
Old Apr 28, 2019 | 01:58 AM
C5Vette612's Avatar
C5Vette612
awesome thanks a lot!!!
Chris
Old Apr 28, 2019 | 09:25 AM
Cutlassmaster
Here are some pics out of my manual. I used below bearings.
Koyo 6007-2RSC3
Koyo 6008-2RSC3
6010-2RS
I'll reread your post to see if I can answer anything else.
Chris
Old Apr 28, 2019 | 09:27 AM
Cutlassmaster
I dont recall that nut on mine nor do I see it in my pics. I will check with a buddy to see if he can answer for you.
Chris
Old Apr 28, 2019 | 11:37 AM
C5Vette612's Avatar
C5Vette612
Thanks for your help I appreciate it. gonna disassemble the bearing housing today, wont be putting it back together till I get the bearings and stuff, where did you get that picture from? is that from the 3 book gm repair manuals? been thinking about picking up a set of them just to have them but their so darn expensive
Old Apr 28, 2019 | 01:02 PM
voda1's Avatar
voda1
Old Apr 28, 2019 | 02:38 PM
C5Vette612's Avatar
C5Vette612
thanks voda1 that's exactly what im looking for!
and thanks cutlassmaster you've both been extremely helpful
To torque tube bearing question
