PCV Mod ?'s
Old Nov 5, 2002 | 07:29 AM
Don Baldwin's Avatar
Don Baldwin
Default PCV Mod ?'s
1. Do you cut the PCV line and if so, where?
2. If you don't cut the PCV line, how do you connect the PCV heat exchange cable?
Old Nov 5, 2002 | 01:14 PM
C5MongooseTX's Avatar
C5MongooseTX
Default Re: PCV Mod ?'s (Don Baldwin)
Have you tried doin a search on it, there has been alot of posts in the past about PCV mods...one of them might say.
Derek
Old Nov 5, 2002 | 01:38 PM
ddawson's Avatar
ddawson
I left the PCV Valve in its original location.
Remove the small rubber line that goes from the PVC Valve to the intake.
Attach the new 3/8" hose to the valve and route it to the coolant tank. Attach the new filter to the metal AC line and connect the hose to the intake side of the filter. The other 3/8" hose now exits the filter and routes back to the intake. :cheers:
Old Nov 5, 2002 | 01:49 PM
THRAP 42's Avatar
THRAP 42
Default Re: PCV Mod ?'s (ddawson)
Don,
What ddawson said with one exception. I tie-wrapped mine to the rubber hose and not the AC line. I was worried about the filter and the metal line chaffing.
later,
Old Nov 5, 2002 | 02:30 PM
benelliwang's Avatar
benelliwang
Here is the complete instruction: http://benelliwang.badassride.com/Engine/index.html#PCV
Old Nov 5, 2002 | 02:38 PM
gojo's Avatar
gojo
http://www.shutterfly.com/osi.jsp?i=...21b308c82425a0
If you go to the link and look at the picture where the new line attaches over the heads you can see the connection. I cut the plastic and left 11/2" of plastic exposed. I used the cut piece to make the connection to the back of the PCV and the 11/2" rubber cover I had cut to go over the plastic.
I used grease to get the rubber to go over rubber.
[Modified by jfpilla, 6:42 PM 11/5/2002]
Old Nov 5, 2002 | 04:19 PM
Don Baldwin
What a great forum! Now have the information I was looking for.
C5MongooseFL- Yes and Thanks.
ddawson- Thanks.
THRAP42- Thanks.
benelliwang- Outstanding writeup and pictures. My questions were generated by your writeup. I couldn't tell how or where you had cut the hose. Thanks for the help.
jfpilla- I also saw your picture but, I still had the questions as above. I'm clear now. Thanks.
You members are great!
To PCV Mod ?'s
