Ground near inside fuse box
Old May 3, 2019 | 12:28 PM
jjc508520's Avatar
jjc508520
Default Ground near inside fuse box
Installing bypass for headlight upgrade - radio flyer instructions say to connect ground to 10mm bolt behind battery near door- can’t figure this one out - have tested a few on the RHS and the only ground I can find is the computer case. Can I use this safely? I guess it just grounds the relay that comes with the kit (to keep low beams on with high).
Old May 3, 2019 | 01:02 PM
jjc508520's Avatar
jjc508520
I’ve got other problems - his instructions show connections to fuses 9 and 10 - located in different places on my 2000 - with #9 as BCM A and #10 as WSW - not what I think I need to be connecting to....
Old May 3, 2019 | 02:28 PM
GCG's Avatar
GCG
Originally Posted by jjc508520
Installing bypass for headlight upgrade - radio flyer instructions say to connect ground to 10mm bolt behind battery near door- can’t figure this one out... ...I guess it just grounds the relay that comes with the kit (to keep low beams on with high).
I was going to ask you what did you mean by "bypass for headlights upgrade" - you came up with a good new name for this, by the way! - when I saw that it was to keep the low beams on when changing to high beams, and realized you were trying to install a Hi-4 Harness.
It seems you are working on the wrong fuse box. It is not the one by the passenger's footwell, it is the underhood fuse box. The bolt he is referring to is in the firewall, if I remember well.
Old May 3, 2019 | 02:34 PM
jjc508520's Avatar
jjc508520
Originally Posted by GCG
It seems you are working on the wrong fuse box. It is not the one by the passenger's footwell, it is the underhood fuse box. The bolt he is referring to is in the firewall.
Brilliant - thank you - it makes sense now - but ripped my knuckles up farting with the inside fuse box and now have to put it all back together!
To Ground near inside fuse box
