Low Oil Pressure..
Old May 5, 2019 | 08:57 PM
DA1984VETTE's Avatar
DA1984VETTE
Default Low Oil Pressure..
,Hi guys, I have this posted in the General Section and was given the advice to post this in the Tech Section. Here is the post: Hey guys went for a drive today and noticed the oil pressure being low. I was driving at about 60mph and put oil pressure show how much it was and it showed 25lbs. I also noticed like lifter noise or something similiar to that. It was really noticeable at 2500rpms when I was shifting gears. I checked the oil even before I left and it was in the operating range. Would i be thinking right that it could possibly be an oil pump issue. With the oil pressure and the lifter type noise or day I say a metal to metal noise. I always see and get some good information from you guys. Would also like to add it drops to 21-23 lbs of pressure at idle. Even reving (slightly reving) it only gets to about 33. Also no oil leaks where I park it.
