2000 FRC ride height
Old May 8, 2019 | 11:08 PM
shawn copella's Avatar
shawn copella
Default 2000 FRC ride height
I bought a 2000 FRC that was lowered with after market pieces. I want to set it back to factory specs. Need ride height specs.
Old May 9, 2019 | 06:04 AM
wscott62893's Avatar
wscott62893
Proper point of measurement is at each jack point on the rocker panel, not fender height. After looking through the data sheets I’ve collected over the years, I have a note stating OEM clearance from jack point to ground is: front 5.95” and rear: 6.15”. Keep in mind, there was variation with each car from the factory. As long as you’re over 5.5”, you’re well into stock territory. The critical adjustment is that you retain about 1/4” of rake.
Be prepared, your FRC will look like a monster truck at that height. Especially if you’re used to the lowered look it has now.
