AC power button
Old May 11, 2019 | 06:50 PM
Surfer G's Avatar
Surfer G
Default AC power button
My AC power button won't stay on for more than a few seconds, the system has been recharged. All other buttons work fan, mode, and auto.
Old May 11, 2019 | 08:12 PM
STRMLNE's Avatar
STRMLNE
The system has been recharged but is it holding that charge?
Old May 11, 2019 | 09:03 PM
bc6152's Avatar
bc6152
Mine did the same thing, flashed for a few seconds, turned off, and no AC... A new compressor fixed it... GOOD LUCK!
Old May 11, 2019 | 09:25 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
just the # 34 relay fixed mine ???
Old May 11, 2019 | 11:56 PM
BigGun's Avatar
BigGun
You will need ac gauges to see what the pressures are and what they are dong to even start the troubleshooting. It could be many different things from a bad compressor (expensive) to a bad outside air temp sensor (cheap).
Old May 12, 2019 | 12:14 PM
Surfer G's Avatar
Surfer G
Thanks guys for the input, Ill check them all out....
Old May 12, 2019 | 12:26 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
this can help !!!
File Type: pdf
To AC power button
