Sac City timing cover tool
Old May 12, 2019 | 12:52 PM
ascastil's Avatar
ascastil
Default Sac City timing cover tool
I'm fixing a leaking timing cover. My last install I used the Sac City alignment tool, the one without the seal in the cover. Torqued to spec, bottom bolts first. I just put the cover on again, torqued the same way, and the tool is real hard to get off the crank. I had to use pliers. I test fit the tool back on the crank and it doesnt go on which leads me to believe the cover isn't lined up. I think this was my problem last time. Anybody experience this? Also when I put the tool back on the crank I can see where one side wants to sit in the cover, but not the other side, like the tool is crooked.
Old May 12, 2019 | 12:56 PM
ascastil's Avatar
ascastil
See how the bottom of the tool sticks out? I think it should slide on relatively easy. Even if I push with all my strength, it wont go on. It cant be lined up correctly. Brand spanking new OEM cover.
Old May 12, 2019 | 05:22 PM
Old School's Avatar
Old School
Are you saying that you are tightening the pan bolts first?
Old May 12, 2019 | 05:45 PM
feeder82's Avatar
feeder82
The bolts need to be loose, the o ring lubed, it snaps in tighten the bolts to spec with the tool in, pull it out install the seal. It should pull right out by hand, it must have moved when you tightened the bolts
Old May 12, 2019 | 05:51 PM
ascastil's Avatar
ascastil
Oops, yes I did. I think I tightened those last on the other attempt. Should I try again, oil pan last.
Old May 12, 2019 | 10:11 PM
Old School's Avatar
Old School
From Sac City Corvette
'One mistake that can be made with all these tools you listed, ours included is tightening the oil pan bolts to tight before tightening the cover bolts. Tightening the pan bolts first pulls down on the cover and binds the tool which would misalign the cover. The pan should just be snugged enough so the tool can rotate and is not binding, then torque the cover bolts and then torque the pan bolts.'
Old May 12, 2019 | 11:09 PM
ascastil's Avatar
ascastil
Alright cool, thanks. I was about to pit the tool back in the tool box and just use the balancer to center it.
To Sac City timing cover tool
