Reverse Lock out Solenoid
Old May 12, 2019 | 08:29 PM
mmartinez's Avatar
mmartinez
Default Reverse Lock out Solenoid
Replaced the reverse lock out solenoid this last week, just as I thought it was a "pita", writing this to share what I had to do to install it. The main thing I learned was to turn the key to the ON position and shift the car into any forward gear, this allowed me to push in the actuator and insert the solenoid easily. It's great not having to be careful when shifting into fifth.
Old May 13, 2019 | 05:06 PM
bighank's Avatar
bighank
Default Disconnected mine about 10 years ago and no problems since
My reverse lock out solenoid was intermittent and got me stuck in the garage about 3 times. I pulled the bottom of the boot and was going to replace it but i saw that it was connected with a single wire. I disconnected the terminal and the solenoid no longer locked out anything. I always start the car with my foot on the brake so it isn't going to move when starting. I did this about 10 years ago and have not had any lock out since.
Old May 14, 2019 | 09:43 AM
mmartinez's Avatar
mmartinez
I guess they fail two different ways, mine would not lock out reverse while on the road, and even thou it would not go into reverse, it would cause gear grinding. After replacing with new solenoid, I no longer have to be super careful when shifting from 4th to 5th.
To Reverse Lock out Solenoid
