Cold Air Induction Grilles
Old Nov 5, 2002 | 05:52 PM
Pipes's Avatar
Pipes
Default Cold Air Induction Grilles
MidAmerica sells Cold Air Induction Grilles that replaces driving light grilles for improved form & function for $69.99.
Why not just remove the driving light grilles altogether? Perhaps adding a Z06 screen?
Old Nov 5, 2002 | 06:38 PM
DsC5's Avatar
DsC5
Default Re: Cold Air Induction Grilles (EricVonZipper)
there are a couple of options:
1) remove the stock pieces and add Z06 screens (I wouldn't leave it completely open)
2) drill holes in the stock pieces and get the same thing you'd get by buying the aftermarket pieces with a ton less hassle of installing them.
I did 3) paint the aftermarket grills body color (white in my case) and install them. I did it for cosmetics alone, I don't believe they make a bit of hp difference.
Here's a pic: :seeya
Old Nov 5, 2002 | 07:07 PM
Mark VerMurlen's Avatar
Mark VerMurlen
Default Re: Cold Air Induction Grilles (DsC5)
How difficult is it to swap the fog light surrounds? How do you get to the back of the surrounds to do the swap? It looks like a long reach from the top. Can you remove the radiator shroud to get to them?
- Mark
Old Nov 5, 2002 | 07:25 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
Default Re: Cold Air Induction Grilles (Mark VerMurlen)
yes, remove the radiator shroud and the center air deflector from under the bumper, then you have complete access to the fog light surrounds. :cheers:
Old Nov 5, 2002 | 10:13 PM
Bob Chapman's Avatar
Bob Chapman
Your painted grills are very cool. May do that myself after I drill mine.
To Cold Air Induction Grilles
