3.42's on an A4
Old Nov 5, 2002 | 06:57 PM
mmorse's Avatar
mmorse
Default 3.42's on an A4
What is needed to reprogram the PCM to change the shift points on an A4 when changing to 3.42s? An LS1 edit? Can the programming be done without it? Can a dealer do the reprogram?
Old Nov 5, 2002 | 07:04 PM
batsallover's Avatar
batsallover
Default Re: 3.42's on an A4 (mmorse)
Depending on what year it is, you might have luck with a Hypertech, but in an A4, the Diablo Predator is your best bet. LS1 edit can get you into trouble if you don't know what your doing. And many of us think we do but really don't. :lol:
Old Nov 5, 2002 | 07:23 PM
Mike Mercury's Avatar
Mike Mercury
Default Re: 3.42's on an A4 (batsallover)
if the A4 has 3.15's already, then reprograming can probably be skipped (except if you also go to a higher stall TC).
Old Nov 5, 2002 | 07:31 PM
mmorse's Avatar
mmorse
Default Re: 3.42's on an A4 (Buckmaster)
Cmon guys, you are not really telling me the best way to do the reprogram. There has to be a better way than buying a $400 predator just to do this one task. I do believe the car has 2.73's now.
Old Nov 5, 2002 | 07:46 PM
vstella's Avatar
vstella
Sorry ..No way around it..The program must be modified to accept the new ratio.Also there are shift points to consider and on/off fan conrol and much more. You may be thinking only one direction but we know better ..there WILL be other mods down the road and right now the Diablo Predator is the product of choice..:D
I've been through 4-5 programs already and I wish I had the predator when I first started to mod.. :yesnod: Otherwise you can use Ed Wright at www.fastchip.com .
By the way ..If your not considering an after market torque converter at the same time you will be spending more money down the road for the same install :yesnod: Also now is the time for a Transgo Shift kit...A absolute MUST MOD for ANY A4!!! here's more info on the Transgo http://www.txchange.com/transgo.htm You can tahnk me later:lol:
If your interested in seeing ALL my mods on my 11 sec daily driver, I've documented them all with pics and videos on my home page...:D
[Modified by vstella, 6:48 PM 11/5/2002]
Old Nov 5, 2002 | 07:48 PM
1HOTVETT's Avatar
1HOTVETT
Default Re: 3.42's on an A4 (vstella)
Do NOT use hypertech--I used Ed Wright and I'm very happy :cheers:
Old Nov 5, 2002 | 07:54 PM
gojo's Avatar
gojo
Is there a tuner near you with LS1 Edit? You should get that one change at a reasonable cost.
Old Nov 5, 2002 | 08:23 PM
mmorse's Avatar
mmorse
What about all these guys that have C5 automatics and have changed gears? You have to figure another $400+ for PCM reprograms on top of the gear install? As far as the other mods are concerned, I don't think my friend is interested in doing all that. He just asked me what would be involved in putting my stock Z06 3.42 dif into his coupe.
Old Nov 5, 2002 | 08:29 PM
Mike Mercury
going from 2.73 to anything does; yes.
I've been driving 10 months and 4k miles with 3.42's with a factory A4 pcm program... nary a problem; not even a hiccup. But mine was only an 8.6% change (had the factory 3.15) and my PCM was able to handle that monor variation.
I agree that reprog will provide better performance; but reprog is not a "must" in every case anyways.
[Modified by Mike Mercury, 7:53 PM 11/5/2002]
Old Nov 5, 2002 | 08:34 PM
MYFRSTC5's Avatar
MYFRSTC5
Any reputable tuner should be able to help you. The Vette Doctors in Amityville, NY are extremely helpful. :cheers:
01Pewter's Avatar
01Pewter
CI 2-3-4-5-6-7-8-9-10 Vet
CI-X Auto-X Champ (street tires)
Cruise-In IX AutoX Winner
I changed from 2.73's to 3.15's.
Before reprogramming the engine would hit the rev limiter in second gear and WOT.
The dealership reprogrammed my car for the 3.15's.
But, I doubt that they would reprogram for a set of 3.42's. :rolleyes:
The speedometer will also need to be adjusted.
You will probably need to go to an after market programmer.
Old Nov 5, 2002 | 08:35 PM
Mike Mercury
Default Re: 3.42's on an A4 (01Pewter)
source?
flat out - not the case with a C5.
[Modified by Mike Mercury, 7:48 PM 11/5/2002]
Old Nov 5, 2002 | 08:51 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Default Re: 3.42's on an A4 (Mike Mercury)
When I went to the 3.73's, Steve told me I was hitting the rev limiter. I thought it was a mis fire, the car drove great with the 3.42 programming around town. The drag strip was where the problem occured at WOT, the shift points needed to be adjusted along with the spedo.
Old Nov 5, 2002 | 08:55 PM
Mike Mercury
Default Re: 3.42's on an A4 (wallstAL)
wallstAL
you're running 3.73's with an A4? YOWZA! :eek:
I take it you have a higher stall TC as well. How to you handle traction issues at the strip?
Old Nov 5, 2002 | 08:57 PM
Mike Mercury
Al; just noticed your:
DRAG STRIP ONLY
BFG Drag radials 315X35X17
Grand Sport Wheels 17X11
TCI Line Lock
remind me to never run against you at the track :lol:
Old Nov 5, 2002 | 09:06 PM
kp's Avatar
kp
You can get away without programming but its a good idea to do it. The speedometer is driven off the rear axle instead of the driveshaft like other cars so that will not need to be adjusted.
For a WOT upshift both MPH and RPM has to be met before the car will shift. The pic here shows stock shift mph/rpm for 2.73, 3.15 and scaled for a 3.42. Its easy to see going from a 2.73 to a 3.42 will hit the rev limiter before it shifts. My car with a 3.15 hits 46mph at 6100 rpm on the 1-2 shift but there is no way with a 3.42 it will hit 46mph to shift if the car has stock 2.73 programming.
Going from a 2.73 to a 3.15 or a 3.15 to a 3.42 will work with the stock rev limiter by looking at the tables but a 2.73 to 3.42 wont. There are other part throttle shift tables that will have to be scaled as well but most people probably wouldnt notice the difference..
Opps, I would find a local guy that does LS1edit tuning, I doubt they will give you a better deal if you just do one or two things but it doesnt hurt to ask. A dealer most likely wont do it. The predator is a good option and so is LS1 edit. LS1edit is not hard to use as people make out if you are just changing basic things..
[Modified by kp, 8:32 PM 11/5/2002]
Old Nov 5, 2002 | 09:09 PM
Mike Mercury
Default Re: 3.42's on an A4 (kp)
KP; great info. Where did you get those screen shots?
To 3.42's on an A4
Old Nov 5, 2002 | 09:27 PM
buzzme's Avatar
buzzme
I went from 2.73 to 3.42 in my Y2K. It was drivable but at WOT I would always hit the rev limiter. I bought the Predator for the sole purpose of correcting the shift problem. I installed the Predator program last Wednesday, the car acted the same as before (hit the rev limiter in all gears at WOT), I sent it back Friday, I talked to Johan @ Diablo today, he claims that they will have the problem corrected and returned to me by the end of the week. Hurry up and wait SOMEMORE. :sleep: :sleep: :sleep:
.....WOT upshifts should be OK but part throtle shifts will go a little higher because the car is made to upshift and downshift at different speeds with different gears....
I had problems at WOT.
kp's Avatar
kp
From my computer screen 5 minutes ago :) Thats what LSi edit looks like..
Old Nov 5, 2002 | 09:29 PM
buzzme's Avatar
buzzme
I typed while you clicked.
[Modified by buzzme, 8:30 PM 11/5/2002]
